Wigwam Jones
Caesar non supra grammati
I could use some help understanding my 3-way crossover network. This is mounted on a board in my vintage ElectroVoice EV Nine speakers, and I'm planning to recap. I know I can just replace the caps with like values, but I'd like to understand more about what's going on here. I'd appreciate any help anyone could give me. I apologize for the lack of photos/diagrams.
Parts:
3 inductors. Large, medium, and small. The two largest are solid-core, the smallest is air-core. No values marked on them.
4 capacitors. 1 uf, 4 uf, 12 uf, and 50 uf. All electrolytic. All marked 25 v N.P.
2 resistors. 1 wire-wound (rectangular block) marked 7.5 ohm 10%. The second is a carbon resistor color-coded to 40 ohms 5% (yellow/black/black/gold).
1 potentiometer.
NOTES:
* The 40 ohm resistor is connected across the legs of the pot.
* The 7.5 ohm resistor is connected in series with the 4 uf capacitor.
* There appear to be two ways to get to the negative terminal of the tweeter. Either from positive terminal to a 1 uf cap, or to the potentiometer, then to a 12 uf cap. Both end at the tweeter negative.
* There is a 50 uf capacitor connected between Woofer Negative and Woofer Positive on the crossover board.
* The woofer and midrange negative are tied together with the tweeter positive. It appears that the tweeter is phase-reversed with respect to the woofer and tweeter.
With that in mind, here is what I came up with:
Paths to Tweeter:
1a) Positive terminal -> 1 uf capacitor -> Tweeter Negative
1b) Positive terminal -> potentiometer -> 12 uf capacitor -> Tweeter Negative
2) Tweeter Negative -> air-core inductor (small size) -> Tweeter Positive & Negative terminal
Paths to Midrange:
1) Positive Terminal -> 7.5 Ohm 10% resistor -> 4 uf capacitor -> solid-core inductor (middle size) -> Midrange Positive
2) Midrange Negative -> Negative Terminal
Paths to Woofer:
1) Positive Terminal -> solid-core inductor (large) -> Woofer Negative
2) Woofer Negative -> Negative Terminal
I understand the purpose of this type of crossover; the inductors set the low-frequency crossover point, and the capacitors set the upper-frequency crossover point. What I don't understand are:
50 uf cap between pos & neg terminals for woofer?
40 ohm resistor across legs of potentiometer?
2 ways to get to the tweeter negative terminal - through the 1 uf cap or through the potentiometer and then through a 12 uf cap?
The air-core inductor appears to run directly between the positive and negative terminals of the tweeter and not be in the path at all, really.
Can anyone explain this to a layman in simple terms and perhaps take a WAG at the crossover frequencies we're talking about here? I realize that without the Henry values of the inductors it is a crap-shoot, but what do you suppose the logical choices might be? I don't have any way to measure the inductance, I only have a multimeter.
Thanks!
Parts:
1 potentiometer.
NOTES:
Paths to Tweeter:
Paths to Midrange:
Paths to Woofer:
Thanks!
