Need some help with an Odyssey Stratos+
N0rt0n
Hey all. I had an electrical storm a few weeks ago that I thought only damaged an older Panamax unit as it was humming loudly when not turned on. I purchased a new Furman unit and got it yesterday. I just got done swapping them out. I got everything hooked up to the Furman, and now my Stratos+ is not working. Seems to be getting no power. There are 4 little fuses inside that all look OK. The rocker switch On/Off is not lighting up.
Here is the bigger problem, I Suck with electrical aside from light switches and outlets. I am unsure just how to check the switch or anything else. I used my Meter on OHM setting and touched the top and bottom poles on the switch. Off = 0 ohm and On = 2.3 ohm.
Any suggestions are welcome as I don't think there is anyone close enough to me to look at this Amp in Bucks County PA.
Any help or suggestions are most welcome.
God bless the fuses...
Yeah, that and youtube videos for electrical dummies. I opened up the amp and checked the 4 fuses inside but was unaware of the one connected to the power cord adapter. I found the video asking AI how to test if power is coming through the switch. It also cleverly had a spare contained in the little pull out drawer along with a few that came with the unit.
