Need some help with Sansui GX-150 rack
Goharlem
I recently bought some sansui gear and the GX-150 rack, but I didn’t get the screws to mount the gear. Do you know what size screws I can use from Amazon? I’d really appreciate it if you could help me out. Thanks a bunch!
If they are a standard rack screw they would be 10-32. This is most likely it.
Network racks are 12-24.
If they are are standard rack screw they would be 10-32. This is most likely it.
Thank you for the reply! Definitely not standard. I have a network rack and the screws for that don’t fit at all lol. I’ve figured out so far the the size that will fit in the cage nuts that are in the rack are Metric screw M4x0.70 it’s just the ones I picked up are way to long.
Ah. It has cage nuts. Yeah who knows then. Sounds like you do know the size though.
I believe they are M4 screws. The length is what I have the issue with. And I was hoping someone who has this model of rack would know so I wouldn’t have to guess.
