Need some MC advice.
voodoocanoe
I recently acquired a MC 2505 and C29, my question is, is there any advantage to running a separate preamp and separate tuner vs a tuner with a built in preamp? space is not a problem.
I know someone that would trade their MX112 for my C29 and I would not have to buy a tuner and the MX112 would match my amp (knob wise)
Should I go for it or look for a tuner?
Thank you. (first time MC owner)
I am not surprised that someone has offered that. It's quite lopsided IMO.
That C-29 is considerably newer, overall a much improved preamp.
If it were me, hold off and wait for the Mac tuner of your choice. You've got the makings of a nice system with the items you have.
Also, remember that knobs and end caps can be purchased to match.
A consideration is the fact that current HD tuners are much improved over older versions. There are more available HD stations and performance, e.g., multipath, interference, noise rejection, etc., is better.
You have to go a long way to really find a step up in phono performance over a C-29, and an MX112 is a step back. MX112 is from the C-26- c-28 generation. If you can find a MR-74 or 78 you'll be way ahead.
Thanks for the advice, looks like I'm on the prowl for a tuner.
Avatar is a 1957 392 Hemi, 1 of 3 that I built several years ago, 2 for the boat and 1 for the tow vehicle.
Ok, After looking at a bunch of MC tuners I found one relatively close to me, an MR78 tuner. Next question is: my C29 preamp has a volume control and there is also a volume control on the MR78 tuner....how does it work with 2 volume controls?
I am currently using a Marantz tuner (no volume control) and am very happy with the results of the C29, MC2505 so far.
Fine choice with the MR-78. It doesn't get much better than this.
The MR-78 has both fixed and variable outputs. Your choice. Think of the variable output (the 2nd volume control) as a means to match levels with other sources in your system.
I think I understand what you mean, I just downloaded the MR78 owners manual from the AKdatabase (thank you AK) and if I use the fixed outs on the tuner then the preamp will control the volume..?
Also, is there a rule of thumb for setting the gains on the amp and the loudness control on the preamp? I have been setting the loudness at 9:00 and the gains straight up at the dots at 12:00
Yes, you are correct. If using the fixed outputs, only the preamp will control the volume of the tuner. The 12 o'clock positions for the amplifier gains has always been suitable in my usage.
Regarding the loudness control, that is subjective and is used for compensating loudness at lower listening levels. Typically, you would increase this at lower levels.
Just curious, what speakers are you using?
Currently I have it connected to my office system which has B&W DM602 S3's, I have many hours of low to moderate volume listening connected to a Marantz 2230 which to my ears is a perfect match with these speakers.
With the McIntosh the bass tends to sounds a little punchy but crisper at moderate listening levels, other than that it's all good and hopefully even better when I put the MR78 inline.
