Mom's house in Albuquerque. Antennas are on a mountain 5000 ft higher than the city and we have line of sight about 12 miles. Except for a single layer of deciduous treetops down the block that we would need a much taller pole to get over. On windy days we can have trouble.
Current setup is a compact "HDTV" antenna bought at WalMart a couple years ago that's supposed to do it all (UHF/VHF), mounted on a pole about 10' above the roof. Works pretty well but we have reception problems with a couple channels, 7 and 16, especially on one TV. Both are broadcast on their nominal channels (no virtual channels on these) so one is the low end of 'high VHF' and the other is in the low UHF.
Maybe too many splitters. There's one at the antenna that runs one output down to the living room TV which is where the problem is (2009-ish Samsung). The other leg of the first splitter goes to a second splitter which feeds two bedrooms. One is not currently used and the other is where my sister stays, and she has a fairly new 24" Sansui that gets all channels.
So I figure the Samsung doesn't have a real good tuner. I've checked and replaced each leg of cable - in fact last year I found a 25 ft section that was bad, was not passing signal at all, and as soon as I replaced it we had TV. I put a Winegard preamp on the roof today (fed by power thru the line from a module inside) and it was worse than nothing, so I'm pretty sure this garage sale unit does not work at all. Just funny that the Sansui works fine downstream of 2 splitters but the Samsung doesn't get these channels after only one splitter.
I'll post a pic of the antenna, it was a $40+ unit supposed to work at 35 miles or something (no longer have the info on it).
Should I get a second antenna just for the Samsung or is there a better way?
BTW it's a stucco house lined with chicken wire for the stucco so indoor antennas don't do well.
