I don't have them right now. I used to own a pair back some years ago. Thinking about getting another pair but contemplating due to their size. If I do get another pair, I'll probably try active crossover, therefore searching for some opinions.Great speakers! Specs and literature should be online via Google search. Do you have photos? They had different horns and tweeters depending on the exact version.
Well dang, the Speakerlab website is unavailable. They had all the K info on there too. I'll hunt around, I could have sworn I downloaded the material.
Exactly what I was looking for. Thank you!The first Speakerlab catalog that gives any dimensions for the K is the 1976-77 catalog. It shows a weight of 220 lbs, 50-3/8" H x 32-1/4" W x 28" D. HT3500 tweeter, HM350b midrange and W1508S or W1504S woofer. Before 1976 the HM350 midrange is shown. After 1977 the WA4000 tweeter is shown with the same cabinet dimensions. Crossover points for all versions are shown as 400hz & 5000hz.
The 1980 catalog is the last one that shows the K. That one shows that the midrange horn is 17" x 6", the tweeter horn ("Wave Aperature") is 8-1/4" x 4" (the same that is used in the S6WA and S7WA), 101db sensitivity with a power rating of 10w to 250w and a weight of 225lbs, same cab dimensions as the earlier models.
Sorry, that's the best that I can do for you.
James
I have Speakerlab Khorns from 1978. They have the HT 350 and HM 350B, and used to have the W1504S woofer. I took the woofer out of the bass bin and built a 5.6 cu. ft. ported bottom cabinet in the shape of the top that holds the mid and tweeter. I added a 2x8 in the rear of the top cabinet and mounted the tweeter driver aligned with the mid driver. I am currently tri-amping them with a Hafler 9300 for bass, either a Lazarus H1-A or Hafler 270 for mid, and Van Alstine modded ST-70 for the tweeter. I use a Rane AC23 for the active crossover. This week, I replaced the W1504S woofers with Goldwood GW-14PC-4 woofers, and extended the 4 inch ports to 4.5 inches. I also time delay the woofer to match the mid and tweeter drivers.
Kind of late to the party but I just added the top speakers yesterday. Both are Super K's. (meaning they have the Electro-Voice T350 tweeters instead of the T35 or Speakerlab HT3500) Makes a huge difference if you have never heard them. This setup fills up the room with sound pretty good. The diagram has weight and other specs. JimAnyone with Speakerlab corner horn specs?
Sensitivity, dimensions, weight, and etc.
Also, any owner out there who has 'em biamped? or even triamped?
Thanks.
Nice. I have never seen stacked corner horns. Have you considered inverting the top pair so the mid and high drivers are closer together? I would want to try that myself if I had 4 of them stacked, except it's probably just too big of a pain in the butt to do it.Kind of late to the party but I just added the top speakers yesterday. Both are Super K's. (meaning they have the Electro-Voice T350 tweeters instead of the T35 or Speakerlab HT3500) Makes a huge difference if you have never heard them. This setup fills up the room with sound pretty good. The diagram has weight and other specs. Jim
