Need to find Tube calibrator
vaathi
baski
Hi all. I went to pickup a SCA35 and the guy mentioned he will sell the tube tester if I am interested. It happened to be a TV-10A tester. I promptly emailed Dan Nelson for calibration and I got a reply that he calibrates only TV-7. I read somewhere TV-10A/U is similar to TV-7. Serial number of the unit is very low. Please help me find someone who is qualified to calibrate this unit. Thanks in advance.
@s-petersen Roll charts are not missing but the supporting HW a la gear stuff is missing. I did not take the pic of the roll chart.
@ferninando I guess that DIY is the only option given that I dont see any qualified Tester Calibrators in SF area. I was willing to send it to AZ, but that turned out to be bummer.
TV-10 calibration is fairly simple, as all you are doing is verifying and adjusting different voltages internally. You'll need a meter with a sensitivity of 100ohms per volt, a pair of alligator clips, and a small screw driver to adjust the sliders on the resistors.
Here's the Navy Tech manual link for the 10A/U. Section "7" contains the calibration information.
