AudioCzar
Nothing is better than occasionally dropping that needle on start up of any LP and hitting the groove perfectly with near zero feedback thru the speakers.
Then there`s the loud, quick slide to the widely spaced first or second groove.
And lastly, the dreaded loud slide, right across, into the first few seconds of the recording.
Always wondered how to combat a sliding needle when dropped at the perimeter?
I found allowing my arm to drop from a slower, startup platter helps. But wondered if there`s anything else?
Wish they made the vinyl a bit better at the perimeter. Noticed many pressings have one side edge angled down causing the problem, which allows the other side to be more flat allowing the needle to not slide.
