'New' ADS L880/2's
David_NC
Always on the lookout for a different model ADS, I keep an eye out for them.Recently, a pair of ADS L880/2's came up on Craigslist. The price was good, the drivers looked good and supposedly worked, the grills were dent-free, but the cabinets....
00d0d_63eh14CJ32yz_0CI0lO_1200x900.jpg 00e0e_7Ge1ZgbsCkmz_0CI0lO_1200x900.jpg
I negotiated a price and went to check them out. The seller is a really nice guy who met me and demo'ed them with his car stereo. Needless to say, they didn't sound good at all with his basic car stereo, but all drivers produced sounds with nothing hinting at any issues. I loaded them up and took them home.
I normally use a pair of really nice L780/2's in my garage system and have always liked them, but wow, what a difference between the 780's and the 880's! The 880's sound like a much bigger speaker, as in more similar to a M12, 1090. 1290, or 1590 than to the 780's. The highs and mids, in particular, were different. I recall a few months ago listening to a member's restored 1590's in a biamp setup and a few of the songs we played that day. Having played the same tracks on my 780's right before swapping the 880's, I was expecting a slight improvement in the bass. That's when it hit me - there's the big ADS sound! Even in my acoustically awful listening area in the garage, I'd have thought the smaller speakers would have been better, but that was not the case at all. The 880's are a big step up for sure. This model seems to be fairly uncommon, at least in terms of what I've seen for sale, but I'd recommend them for a larger 'bookshelf' speaker.
Now I have the dilemma of leaving them as-is as dedicated garage speakers, attempt to repair the split in the seam, or using one as the center channel in my surround system with M12's as the mains, which was my initial plan. After listening to them, I think I'd rather use them as a pair for music vs a center channel.
I can handle the minor cabinet repairs - refinishing, filling a nick here and there, but I'm not sure about the cabinet split. It's bad but doesn't look as severe in person as in the pics.
One kinda cool thing is the sticker on the side of it.
From what I could find online, it's from the mid to late 80's, so it's period for the speakers. Perhaps it should stay.
00202_iBtbwuDrOIYz_0CI0lO_1200x900.jpg 01313_koQNAPIYjakz_0lO0CI_1200x900.jpg 01616_hLct1HPj1dbz_0CI0lO_1200x900.jpg
I have a pair of L570/2's with that same cabinet and grill design. You could probably fix that cabinet with some glue and clamps placed length wise and side to side.
I saw something online a while back where a guy cut through the joint with a saw. He cut the area straight down through the split area. This allowed him to close the joint, but I can't recall if he had to add blocks inside for reinforcement or not.
How would you clamp the blocks with the front baffle in the way? Maybe a coping saw with a thin blade to cut through the old glue and clean it out? I would be afraid of using too thick of a blade and remove too much wood.
Nice... I briefly had a pair of the 570 model, which I thought they were very good but I have to bet that these higher end ones sound even better. Mine were black and I like the finish on yours much better, even if it is in a bit rough shape. It does seem that it shouldn't be too hard to polish them up a bit and even that seam split part seems like something that ought to be possible to repair without too much trouble.
Blocks can be clamped with those clamps with squeeze handles. I have a pair that has one removeable part that reverses and goes on the other end to act as a spreader. If that's not possible, I'd use the 18 gauge brad nailer. The holes from the heads would be the least cosmetic worry! Perhaps I should just wait to strip off the veneer, fix the edge, and find someone to re-veneer them. I don't have a lot in them, so I can do a bit and be OK with it. At least they'd look really good after all that, I'm sure. I recently got a multi-tool aka oscillating tool, and the semicircular blade makes it really easy to get straight cuts with way more control than even a hand saw. The hard part will be taking them out of rotation to do anything extensive to them!
Yeah, I have one of those little oscillating saw things and what you're talking about certainly would be a great use for it. I've only used mine on a few things, but I have to say that it's a really incredible, really versatile tool.
I got mine right before helping with a deck and lattice privacy wall rebuild. It's been great for times when I'd drill and cut with a jig saw, for example, and perfect for cutting lattice. The sanding head is much more useful than I'd imagined. Mine is a DeWalt and has a quick blade / attachment change, which is very handy.
Got my L880/1 new in '85. Added a pair of L880/2 in black painted finish a few years ago.
Yes they are lovely speakers.
I'd keep eye out for a better cabinet pair, maybe needing new drivers. Use your drivers to repair.
View attachment 2402885 View attachment 2402886
View attachment 2402908 View attachment 2402909 View attachment 2402910
I have a set of these, I really like them. But I like all my ADS speakers.
Maybe Boston Tom@ will Pop up...he's done alitte ADS cabinet repair. I still have a set of 810's I have to do, (water damage).
I have a pair of the l880/2. New to me about 12 months ago. I refinished the cabinets - teak veneer. Look and sound great, and in rotation.
Your cabinets look to present a challenge. You might have to reglue with new bracing and then re-veneer. The beveled corners might be difficult. I worked on a pair of Klipsch Forte that were in similar shape. I glued, stabled the cabinet back together and used Bondo (for wood) to create a smooth surface for new veneer. Great results.
Good luck to you!
