New Aiyima A07 MAX Amplifier - Small Footprint, Good Sound
J English
Photos: 3 amps side by side (MAX, Fosi V3, original A07), close up of front of the A07 MAX, rear panel of the MAX)
This is a mini-review of the new Aiyima A07 MAX class D amplifier from my "average Joe" perspective. Aiyima was gracious enough to send me a unit for review and evaluation.
I found the amplifier to be a lot like the Fosi V3 - apart from the noted Stereo/Mono feature, which I have not made use of.
While I think the Mono capability is an interesting addition, to me it's kind of a halfway step to "true" small monoblock Class D amps without integrated volume pots. The mono capability would seem to me to be most useful to people with a medium-sized listening space with medium to high efficiency speakers who want to use the 48v power supply option to get medium to loud volume levels. (You could do this in a smaller room or desktop setup, but why? Even with the 36v power supply I can get to very loud levels in my workroom with my 87db efficient KEFs.)
During the past week, I have switched back and forth between the older Aiyima A04 and A07 amps, the Fosi V3, and the new A07 MAX amp, and varied between use of the Fosi 32v 5a power supply and the Aiyima 36v 6a power supply. All gave good sound and satisfactory volume levels. There were no noticeable power on or power off pops. Using a variety of sources, I did not detect any truly notable differences between the amps. I like that the V3 and MAX amps are vented, and I believe this should help add to the product longevity. This is even more important for users who are making use of the 48v supply to get to higher volume levels. With the 32v and 36v power bricks, none of these amps get very warm to the touch at all. All of these amps can get higher volume than my SMSL AO100 amp, which I like for the dining room (remote and integrated bluetooth) where I don't need high volume levels at all.
I am using the V3 and MAX amps with the supplied 5332 op-amps. I had changed out both of the older Aiyima amps to 4562s.
I like the very clean and simple appearance of the A07 MAX. Aiyima has made a nice case and clearly designed the product to compete with the V3. The lack of top case holes might be a plus for some users as a) it makes it less prone to liquids or other dust entering the case and b) it makes it stackable. But since Aiyima has no matching components, that's not a huge consideration. I especially like that the Stereo/Mono switch is well recessed from the case so it cannot be bumped accidentally. Good design work there.
It's a little thing, but given how close all these amps are, little things matter...IMO the knob is not as nice to use as the Fosi V3. It's just a little bit smaller, and in my sample, it mutes to about the 3rd volume marking. Because the Fosi knob is larger, it's easier to grip and quickly change a volume level over my shoulder, which is how my setup is arranged. If you are looking right at the amp on one's desk or shelf, that's less important - but I still think that Fosi wins the ergonomics award for the knob. It's got a little better control to set a low volume level easily.
Another feature of the A07 MAX is the offset speaker jacks. Yes, they are of higher quality and thickness than the Fosi. They stick out more in the back, and the best way to connect safely is still by using banana plugs. The provided jacks don't make connecting with bare wire easier or advisable IMO. So it's kind of a difference that makes no difference, save perhaps for the users with very wide or angle-type plugs - (probably same users who are using the amps as mono units?).
All of these amps do the basic job of amplification for small to medium setups and in a nice way. I think for me personally, the Fosi V3 still is the nicest to use and has the most attractive appearance.
I think the next logical step is for one of the Chinese manufacturers to a) solve the noted load dependency issue for frequencies above 10k; b) create an attractive and good-component built true monoblock option (with the power supply in-case with the amplifier) that would compete with the Hypex amps but at a lower cost; c) create a matching solid state preamp for the monoblocks with a high-quality volume control, 2-3 inputs, and a remote.
It's great to have so many good choices right now in these compact amps. I am very glad that Aiyima is continuing to develop some solid state, clean, "no frills" units along with their tube and more "steampunk" looking options. The A07 was the first small amp I'd bought since my decade-old SMSL SA-50s, and it was an improvement, which the A07 MAX takes further still. Since the MAX came out, I understand that Aiyima has already beefed up the main power caps rating from 50v to 60v to provide a bit more protection for people using 48v power bricks. This is in line with their improved attention in this model to using good quality caps, inductors etc. similar to Fosi in the V3.
If you are looking for a very good, basic amp for nearfield/desktop/small room system use, the A07 MAX is a solid choice.
Think it can it drive lower efficiency speakers like 84db 4ohm Spendor S3/5 monitors? I have those in my home office and would love a small form Amp.
I think it could, if you got their 48v 5a power supply and don't need to play extremely loud...capable of about 120wpc with that brick...
  • Like
Reactions: BMC
@J English thanks for the review. I was about to order the AO7 Max and noticed that the AO7 is currently offered at a significant discount. Do the Max upgrades significantly improve performance over the base model? Or should I take a long look at the Fosi before committing to the Aiyima?
The original A07 is still a really good amp. The MAX is not a huge improvement, in my view, particularly if one's not using the MONO capability. The MAX and the Fosi V3 have better cooling, so maybe that adds to the life of the product a bit... The original A07 can get very loud with a 32 or 36v power supply, the V3 and the MAX both would need to use the 48v supply to play as loud. The main value of the Fosi to me is the different tapered volume pot, you have more control over playing at softer volume levels. Hope that helps!
Have you had a chance to consider the new Aiyima A70 (not A07)? I’d be interested in how you think it compares to the previous Aiyima amps, and to the Fosi amps.
Dave: I'm holding off on new small amps for now, but the A70 looks promising, also the new Fosi V3 monoblocks. The Aiyima A07MAX is a good amp, as is the Fosi V3. The different taper in the volume pot makes these amps much more useful for quiet listening than the original A07, which frankly is a lot of my use cases for these.
I'm currently using the Aiyima A04 with some (free) Burson Audio V5i op-amps in the bedroom, and the A07 MAX in my sunporch system, fairly small rooms.
The PFFB implementation is a good step forward, but frankly for my aging ears, having about a 0.5 dB rise in treble after 5 khz is not a very big deal...
The thing I really need to use these in some of my other setups is a good modern analog preamp. I have older ones (NAD 1020, Nikko Beta 20) but what I really want is for one of the Chinese makers to develop is their version of a Schiit Saga S preamp, with a good stepped attenuator, ideally with a phono card and multiple line RCA analog inputs. Schiit also indicated to me they are working on something new with regard to an RCA (non-balanced) SS preamp, but so far there are no actual details.
Over at Audio Science Review, there are not many folks who yearn as I do, since they are really into DSP and room correction and thus are only really excited about higher level, digital preamps.
P.S.: A number of people have pointed out that getting two A07 MAX units is still cheaper than the new Fosi monoblocks, and with their mono capability, provide a cheap monoblock solution if you are willing to live with matching the volume control levels on the two amps.
@J English, you and I are in the same situation. I'm currently running three A07 amps with my tri-amped La Scala speakers. I've been very happy with the A07s but would be willing to upgrade in order to address a few deficiencies and gain some features (e..g., linear potentiometer (knob), selectable input sensitivity, remote on/off and volume, trigger in for on/off, single power supply that could support multiple amps).
Ideally, I'd love to see a 6 or 8 channel amp (each channel adjustable) with power supply so that I could cut down on the number of boxes and power supplies I have to deal with.
I did some testing with the A07s as part of my journey towards tri-amping and DSP. I had wanted to identify a "safe" setting on the A07s where I could be sure they wouldn't overpower my drivers. This thread and this thread describe my efforts.
Me too! (Although I don't need a phono input). Currently I use my streamer for volume control. I'd like to have a preamp so that I could integrate other sources and for volume and tone controls.
In the "Klipsch Korner" forum, there's been some discussion about the different audio op amps that can be used in the Aiyima and Fosi amps. Contributors have tried a few different ones (NE5532, LM4562, MUSES02, Sparkos SS3602) with the units. The review (by @Gigantic) of the Sparkos op amps reports that they made a remarkable improvement on an already good sound.
Yeah, I tried the Burson V5i op-amps since they were free, my ears are not sensitive enough to really hear differences between the supplied 5532s, some 4562s and the Bursons, so I am staying with those for now...people say the Sparkos are good in them, but the cost has kept me from pursuing that...
I like the idea of the Fosi monoblocks (pure amp, no volume control) but am content to wait for now until the preamp situation sorts out...hopefully there will be a good choice for that later this year? I was also hoping the Fosi monos would have the power supply integral with the chassis, but no such luck. That being said...the appetite for them seems to be strong...they funded their Kickstarter in an hour!
Do you know about Buckeye here in the US? He's very active on ASR and makes Hypex and Purifi based Class D multichannel amps. Depending on your appetite for an "all in one box" multichannel solution versus cost, his builds would be worth a look. He's a great guy, very responsive... Simple cases, integral power, solid US-based service/support. I may get something of his in the future but I don't really need 150+ wpc or more than 2 channels at present...
Buckeye Website
Buckeye Website
Thanks for the pointer to Buckeye. I see that Buckeye offers two 6 channel amps (Hypex NC502MP and Hypex NC252MP) that have impressive specs and look very appealing.
I'd be very keen to see what Buckeye could do with a 3255-based product. It would be neat to see them offering a product similar to their Hypex-based ones (i.e., like a putting a number of Aiyima or a Fosi amps in a chassis and combining it with a good power supply).
Buckeye Website
Another Class-D amp I had not heard of before.
I have two Fosi amps on the way to give class-D a try.
I like the built-in power supply idea, based on the one's I looked at they are using Hypex SMPS power supplies like this: https://www.hypex.nl/products/smps-family/smps1200a400.
It seems to me that with the availability of pre-engineered/assembled class-D amp modules and power supplies like the one above, may help launch a "home-brew" amp movement like there is for speakers.
I've had my A07 just over a year and enjoy it. However I never realised how capable it was until a speaker change recently.
