I find myself in unfamiliar territory and could use some assistance from those who have more experience in the world of amps/receivers needed for sub integration. I'm looking for a new, compact 2.1 receiver to power a pair of 12" Rolas(in mono) and a pair of 4" satellites in a console. Does someone make such a unit? I've eliminated AVR's due to their complexity and size. This a temporary solution until I get the console amp sorted out.
I've come across some mini 2.1 amps and 1 compact receiver(Pyle PTA24BT) with FM reception. Since there was no tuning control knob, the Pyle got some negative comments due to the complexities of only changing stations via presets. The Pyle also lacks a dedicated sub amp, though it does have a sub out connection. Might not be a total deal breaker. My wife will be the primary user of the system so simplicity is key.
A list of must haves/wants.
1. Space limited to 15" W x 6" H. Console shelf is 15" deep but back is open.
2. Dedicated sub out and front sub control.
3. Bass and treble controls.
4. Tuner with display and tuning knob for ease of station changing. She has 1 primary favorite station but during the holiday season there will be others that get tuned in.
5. Minimum of 1 pair of line level RCA inputs.
6. BT is optional even though I'm not sure if she would use it to connect with her phone.
7. I'll have fun setting up 2 & 3. Beyond initial set up I'm not expecting her to adjust these.
None of my vintage receivers will fit in this area so I'm looking for a new 2.1 unit with FM reception. If not possible I'll look into older 2.1 AVR's. My limited experience with those that have passed through here, is that space will be an issue.
Budget preferably 200 or under so cheap and cheerfull Chinese built recommendations are welcome.
Thank you for reading my long post.
Mark
Mark
