Oneoff
I’m trying to figure out if it’s only in my head and what is actually the problem.
So, I had to replace an old scratchy dual motorized Alps pot in my musical fidelity A5
Integrated. I was 100% happy with the sound of that amp before, but I didn’t have any choice because the old pot couldn’t be cleaned, and I had some loud pops In my speakers.
I ordered the new RK27 50kA dual pot from eBay in Germany, the seller looks legit, the unit arrived and it looked like a very nice quality, even better then the old one installed. I desoldered the old and installed the new.
First impression- the motor is smooth, a little more mechanical resistance, feels ok
But... something is slightly different with the sound I can’t say exactly what,
The soundstage changed, stereo image, the sound is maybe brighter now?
Hard to tell without a proper A-B comparison with the old one...
Measuring the pots outer solder lugs shows:
On the old pot the left channel total value is around 700 Ohm less then the right.
On the new pot the left channel value is almost 800 Ohm more then the right.
Some thoughts and questions:
-Could this mismatch be the source of my problem with the sound?
-How this difference translates to the output? Is 800 ohm can turn into an audible difference?
-Is this difference in the pre amp stage usually get compensated by the manufacturer somewhere in the circuit?
-Would it be a good idea to solder a resistor across the right channel outer lugs in order To match it with the value on the older pot? Will this change the logarithmic nature of the pot?
-Could some of it be related to the need of some ‘burn in’ time of the new pot?
I’m planning to order some dummy load resistors and measure the outputs on the amp.
I’d love to hear your thoughts and ideas,
Many thanks! And sorry for a longish post...
