David_NC
Like many, I'm always looking for a new project to add to my others! Over the weekend, I found a local guy liquidating his 'collection' due to downsizing his living space. I picked up a couple integrated amps - HK A230 and A300 (A30K, actually). Both are very good to excellent cosmetically and are complete. Both appear to have been updated somewhat - I see a few new caps in the A300, and the A230 looks to have had a couple of its multi caps replaced with separates under deck. I'm probably going to do the same with the rest of the caps. I've ordered some terminal strips to make this a bit easier and tidier vs just having them suspended by their leads.
Any suggestions as to what caps to use for this and any tips would be appreciated. As to these amps, I'm not finding out a lot about them. They look very simple and roomy underneath, for integrated units, compared to my Sherwood! My only tube recap experience is a Dynaco ST-70, which I found easy and straightforward, and much of that is due to that model being so well documented.
The A230 has an assortment of EL84's and an RCA rectifier. The small tubes are Mullard, Raytheon, and Westinghouse. The A300 has Magnavox 6v6GT's and GE and HK for the others. I'm curious as to opinions of these amps. I'd like to power them up before working on them. I have a DBT and a variac on hand as well as some load resistors, so suggestions for this are definitely appreciated!
Here they are. I haven't cleaned the chassis yet, but they look like they will clean up nicely. The A230 has some ugly wooden blocks attached to the sides, but they sure make it nice to work on!
I also picked up a Hickok 533A in nice condition. It's in some sort of big metal case that is designed to sit up vertically, so I assume it was used as in a retail setting vs being used by a service tech. Once it's proven to work properly, I'll build a much smaller wooden case with a cover like most of this model have.
