Hi All
Just started new project Hk870 amp hk825 preamp tu615 tuner and cd401 cassette deck. Found on the auction site, was looking for a high current amp to drive my new infinity iiia speakers. Was impressed with the reported damping factor of 125. Plus I have been eyeing the cd401 cassette deck as one of the best around and the seller reported it as working.
First out of the box was the cassette deck and it was indeed working nicely. Next out of the box was the amp and no joy not even power lamps, even though the seller advertised it as working.
Opening the case I found what surely was the problem a burnt resistor
Removed the resistor and found it wasn’t burnt after all. It was the glue used in this equipment had eaten the exterior away. This resistor measured good but didn’t have the -24 volts it was supposed to have. I decided to replace the 2 caps and found this on the back side of PCB-4
I am thinking maybe fedex dropping the box and the blow fractured the ckt board?
Any suggestions on how to reinforce this ?
My search if the missing -24v continues until I find this
Notice how the 2 traces on the top are fractured with the break in the main board PCB-1.
The top trace carries -55 v to Q4 which then outputs -24 v. I bypassed the fracture with a wire and now the amp is working. Next steps are clean glue from the boards and order new caps.
