There have been reports of either the speaker relay or the two large capacitors on the board preventing removal of the board downwards through the slot in the horizontal chassis. I don't remember it being an issue before, but this AU-719 needed to have those two large capacitors (2 x 470µF, 63V), removed before the board could slide out. The relay isn't a problem (despite the new relay being about 3mm taller than the old relay), and the fact that it remains below the slot in the chassis when in its final position. The relay might be a problem if extracting the board upwards, but you can only do this if you disconnect the board completely, and there is good access to the solder joints for the relay, so it can be removed if needed.
To extract the board downwards, you have to release the four main PSU capacitors from their clamps. Additionally and in this case, I had to de-solder 2 pairs of red & white wires, one grey wire (from the transformer), and 2 thick brown wires going to the mains fuse on the board. You also have to release ground tags in two positions (between the Driver modules), and the power feeds (grey & orange) to the Control Amp and Phono Boards.
