Hello all and thanks for contributing to this awesome forum. I've been getting a lot out of it already.
I just picked up this SX-780 for $200 which I think is a pretty good deal. (Side note, also picked up a pair of Bang & Olufsen Bevox 3702 speakers with it for $60). Everything works on the SX-780 with one minor annoyance which I'll get to shortly. As far as I can tell, it doesn't look like it has ever had work done to it and also doesn't appear to my untrained eye to have any immediate issues, but I'll add pictures of the inside in case anyone sees something. I was able to set the DC balance (they were 130mV and 65mV before adjustment) and the meter drive per the service manual.
So here are a few questions.
1) The one issue I have is with the power relay. When powered on cold the relay kicks on in about 5-7 seconds. But sometimes it kicks back off again...and then on again. But it only seems to do this cold. Once it's warmed up, I haven't seen it kick off. Any ides what causes this and what I should look to replace/fix?
2) The solder joints on one of the Power Packs look rough (the one I included a picture of). Do you think I should reflow those?
3) Since everything is working good (other than the power relay issue) I'm tempted to leave well enough alone for now. Or should I go ahead and replace the common failure points? I know it's typically recommended to at least change the power and filter caps even on a working system, and the relay too I think.
If you notice anything else from the pictures, feel free to enlighten me.
Thanks,
Steve
Thanks,
Steve
? Go from there.
