New Open Baffle Build
KeithTr
AK Subscriber
After I built my first open baffle speakers - a modified a version of the decware zen - the WAF (wife acceptance factor) was less than ideal due to the size. So I just had to try again, this time with a modified rough version of the duet - but my design 100 pct.
They really look great and sound pretty good so far - still playing with placement and balance between drivers (included an L-pad in the crossover). My room not ideal (lots of reflective surfaces, but still worth the effort i think.
Final version:
Build was made using walnut veneered plywood (I bookmatched the baffles), walnut edging,
(base missing in above photo)
1/8 aluminum edging to connect the sides and the baffle (used a grinder to shape the profile at the top),
some low profile adjustable feet so I could level or slightly tilt the baffle (which was set at 4 degrees back). The baffle was made using a glue up of 3/4 and 1/2 walnut plywood for a 1.25 inch thickness. Laminating like that adds significant stiffness and prevents some resonance. Used 1/4 black acrylic for crossover boards - made a template after laying out the components and then drilled both boards at the same time -3 different sized holes though - one for l-pad, one for zip ties, and one for component leads.
Drivers were the SB Audience Bianco 15 inch for the bass and the Lii Audio Fast 12 for the full range - crossed over about 235 Hz.
The cost of these drivers is reasonable compared to many alternatives, though i might go a bit more upscale should i ever get the urge to try again.
BTW, the system shown here is the Hitachi HCA 7500 preamp and the HMA 7500 MOSFET amplifier with a WIIM Pro Plus streamer. I restored bothof the Hitachi units, which are in great physical and operating condition.
Hope you enjoyed! Keith
How do the sides affect the back wave? Is it better than OB speakers that don't have them?
I've only built two sets of open baffles so far - a decware zen style baffle with no sides and the one pictured in this thread. No question the bass is better (when adjusted properly) in this new pair. It's also influenced by placement relative to the back wall and the angle of the speaker. And all the literature I've read says that if you are using a relatively narrow baffle (these are about 38" high by 20" wide) you absolutely need wings on the bass to help avoid a sharp decline in output due to cancellation. These were modeled after the Duet open baffle speakers (though my design is entirely original, from the measurements to the construction, to the crossover). The zen style uses a full range driver with no crossover and no wings, so it's not terribly surprising that heavy bass is a little challenged and all full range drivers are going to have some limitations. I'm no bass head, so not trying to max out, but if I play something like Michael Jackson's Thriller, or Beat It you get plenty of thump on this new pair.
Having moved the zen style to my smaller office, I love the way it handles anything jazz or acoustic - you just hear the instruments like they are right in front of you. Pianos, sax, guitar all sound great. In that case, the full range driver plays better low than very high, which I don't mind since at my age I'm not hearing anything above 15k for sure and probably more like 12-13k.:) Not sure if decware still using this driver, but the one I used is the same that they used to use in their (much more expensive) speakers. I still have love for my KLH refurbished model 6s which I still use, but I get why open baffle has such a following. It really depends partly on the kind of music you play and how often you really need loud, deep, bass. For me, both of these are fine, with better base in the 2-way.
