New Sansui 2000x - boomy and thin?
Sometimes. Old caps can lose their films and reform. Was looking at a fix and repair Sony STR-7065 being sold with bad tuner section was checking out the amp part had switched to FM which tuning meters seemed like it was tuning but no output. Some reason left it on in that state put the headphones down was looking at something else and after couple minutes picked up the headphones heard faint audio coming from them put the headphones back on FM section slowly was coming back to life but with some distortion. After that experience after redoing the power supply and part of the amp section of a 3000A testing it out switched to AM tuner seemed dead. After the Sony experience let it sit a few minutes and after a time the AM section did slowly come back to life.
But then again old caps can blow up. The SX-1500TD (1971) currently in the living room is of similar vintage and after rebuilding the amp card (new transistors, caps, trimmers) and recapped the power supply, I usually test a unit at that point for a bit at each stage of doing the recaps before continuing the recapping process. Sounded pretty good at first but then started declining in sound. Continuing the recap when I got to a tone control board a pair of 3.3 uf caps had blown their bottom seals and were looking baked. Read something like 5.5 uf and I forget what loss value I was getting with my $20 Amazon tester. After recapping the rest and upgrading the output caps from the 1000 uf I originally put in to 2200 uf Nichicon fine golds it sounded really good. May not be the most accurate by test numbers but a pleasing one to listen too.
Somebody gave me a Technics SA-5170 (~1977) they had been using as a garage system. Really dirty inside so cleaned it up and gifted it to a friend with a pair of speakers to a friend to use as the office background music system. Originals seems okay but after a year of use walking by it you can see the pair of filter caps through the top screen and I noticed one was much taller than the other. Surprised the filter cap they used in it could expand that much without blowing its seal. I got them to let me recap it has seen a number of years of weekday use since then.
Recapped mine. Used Silmic II and did Conrad's mods to it can see what some people complain about an "air brushed sound" to them. Others love them. For the most part on units I have used Nichicon UPW an UKL mix with either Wima MKS2 or Kemet R82 films sometimes some Panasonic polyester but they can be huge. Have used some others like Panasonic FMs and FCs and with axials often used the Nichicon VX series but those seem to be in the process of being obsoleted. Also like old Pioneers some noise/failure prone transistors good to replace them too.
If I remember right, the third digit of the Sansui serial number is the year, next two digits the month. But you also need to know the approximate vintage of the unit so you can recognize 9 is 1969 and 0 is 1970.
I have seen posts you need to check board numbers in a unit using the service manuals as a guide. The 2000A and X are very similar and production may have overlapped have seen posts you can have one unit with some boards in it that go with the other unit. On cap values always check the boards and take an inventory of what was installed to verify things. Sometimes what got produced has some differences from what is shown in the service manuals.
Cost partly depends on what you need to buy to do it, if you need to buy some tools and other supplies to start. Would guess in the $60 - $80 range. If you mess with the output transistors you have thermal paste and mica washers or the silicone silpads.
On the big caps used the one Conrad suggested as his go to for these unist, the Nichicon LGU2A272MELC, 2700 uF, 100 VDC which fit my 2000A clamps. Lower value in the same line can be used to the other smaller clamped snap in type capacitor. Usually screen filter caps by the original diameter (to fit the clamps) and voltage. Usually step voltage ratings by at least one increment, say 50 replace with 63, 63 with 80. With that screen often not many choices left, hopefully all the choices are not more than I want to pay. Then may consider using a smaller cap with a wrap to hold the smaller cap in the clamp.
Hey Bilbo - I did a deoxit cleaning bc it def needed it. I did just the dials, but it helped.
Question: someone said that playing the unit will rejuvenate the caps if its been sitting. Is there any truth to this?
It can help. I’ve noticed the same thing with speakers that haven’t been used in a while. I agree with Automojo. The amplifier and the speakers need to play nice together. This is just the nature of audio. You can’t take any speakers and expect they will sound good with any source. I have many experiences of this, and it defined how my stereo systems evolved.
Hmmm. That sucks automojo.
I really like the kg's. They sounded awesome w that Nak, but that was a DC amp.
I had heard (i think, but i'm getting sorta confused at this point) that based on the efficiency of the speakers, they'd work well in this scenario. The 37 wpc isn't going to do it in your opinion, huh?
This is one of the reasons why the enthusiasts on this forum have multiple speakers and amplifiers. I have 6 amplifiers right now, a number of bpc type receivers, and 8 sets of speakers for this reason. And I won’t be deciding what amp and speakers will go into our bedroom system until the renovations are done and the furniture is in the room. However, all the speakers I am considering for that system are WAF approved, and I’m likely going with the McIntosh MA6200, which I know doesn’t play well with the Kef 103/2s. But even so, I will still give them another chance because there are so any variables.
Well it doesn't sound like it so far.
The KG's are efficient-but sound even better with more power, and control.
My 5.5's sounded superb with a 200wpc direct coupled H/K amp.
They became a totally different speaker then driven by a 100wpc Carver integrated amp.
But-I just think the amp in the Sansui is a bad match-regardless of it's power rating-for the KG's.
Quality watts is what's really important-but I think 50-80 would be a minimum-I think the Nak is 70 mor so?
I certainly think you can recap it, and see.
I just don't think it will change that much.
I agree-the KG's are awesome speakers-and worthy of the proper amp.
Transparent they are-and they frankly are just passing on the Sansui sound.
I certainly would not dump them just to run a old receiver.
The fact that you found a great match with the Nakamichi-well enough said IMHO.
Or you could search for another vintage looking receiver and hope it works better.
Personally I would just run the Nak-or explore a bigger quality amp.
I get the retro look-but as you found-it can be a crap shoot.
Those pieces are old-and most were mid-fi at best even when new. Fairly colored sound and most had poor control of the bass, as you are experiencing.
Frankly if your looking for a different look-there are a number of good-80-100 watt per channel integrated amps out there that would almost guaranteed to sound better then the Sansui.
Cambridge Audio/Schiit, Marantz to name a few.
Outlaw Audio makes a awesome retro looking and performing receiver as well.
If your looking for a slightly "warmer sound"-the best route is a good tube preamp (the new Van Alstine gives you the best of tubes-with out the drawbacks) and a solid state amp.
But that's a significant expense.
All of these choices may or may not match to your taste.
And your finding the exact problem we all can encounter when swapping out a good sounding piece, for the un known.
Seems the Nak is the hot ticket here...
Well, here's an update.
I did the Crites update on the speakers - new caps, new titanium tweeters. I'm still in the listening phase and trying to see what I think. Digital sources seem pretty good. Records are still hit or miss. I replaced the cart on the rotel rp 3500 w/ an ortofon red and the audition continues. Def not an immediate 'wow' factor - but that, as they say, is another story.
I can't seem to locate someone around here who does service on these things. Anyone know anyone in Western MA?
Mike @ Hudson Valley Hi-Fi, but he's in NY State. Or the shop in Hartford near the Audio Museum(can't remember name.....Brain fart). Both very good and about as close as you'll get in N.E.
My 2000, 2000A, and 2000X don't play well with my KG 2.5's. But they DO sound outstanding on my Heresy's for some reason or other. I overhauled each 7-10 years ago.
Oh man, so probably this holds true for the kg4.5's too. I thought setting up the crossovers and tweets would help it out, but errr. I guess a recap isn't really going to change that either.
I'm sooo tempted to put the Nak back in the den. I don't really have a great spot for the 2000x either. Bummer.
