New SPEC in da house!!!
godawgs
What Bill of Rights?
Here's what I bought...
Pioneer
SPEC-1 pre 9/10 one small 1/8" light scratch
SPEC-4 amp 9/10 need to replace meter lamps
DT-400 timer 10/10 neat, but don't need
PL-L1000 T/T 8/10 no needle, but I have a spare don't need, but....
SG-2 EQ 9/10 don't need
RG-2 Proc. 9/10 don't need
TX-608 tuner 9/10 this is a black dial TX-6500 I've read
RT-909 R/R 10/10 I need to replace belt though
Sansui RA-900 rev. amp 9/10 dont need
AKAI GX-F66R cassette deck WITH the remote controller 9/10 don't need
This stuff is really mostly mint and was used on a daily basis. Sorry can't take a photo yet. Remember, I bought this from a friend, so I didn't want to steal this stuff. He bought most of it in Germany when he was in the Army.
:thumbsdn: :thmbsp: what do you think?
I know this isn't a steal or thrift store find that some of you may have had, but...
I gave my friend $1350 for all of it.:thumbsdn::thmbsp:?
I may get rid of some of the gear , but not yet. This is for a third system,(no I'm not rich), so I'll keep it pretty simple.
I'm pretty sure the TX-608 is a TX-6800 with a black dial. I own two.
I also have an RG-2; I run a tuner through it, to expand out compressed radio signals. Plus, it matches my flouroscan amps.
Stand corrected, you are right about the TX-6800 and the TX-608, same thing except black face.
I have my tuner out connected to the input of my RG-2, and the output from the RG-2 connected to the tuner input on my integrated amp. I use it this way because I only use the RG-2 dynamic expander with my tuner (several local stations use a compressed signal).
The RG-2 and SG-2 could also be hooked up to one of the tape input/output pairs on the amp, so you could engage them when you wanted to use them, or cut them out of the audio path when you didn't.
[edit]: You should go over to the Pioneer Manual Scan Database and get the owner's manuals and such for all your new Pioneer equipment. They'll do a better job of explaining what everthing does, what all the options in connecting things up, and what all the controls are for, than I can.
