klipschoid
Yes the amp powers up ,heaters light but that mallory gets real hot ,and amp puts out very low distorted volume ,no tripping breaker or fuse tho,so i wont power on again,till those caps are replaced ,again thanks
Cap can is not getting hot now with output tubes removed,is it possibe i had a shorted tube? Ill know more when i put some known good tubes in it
Those green wires that went to the octal is a 6.8 or so tap for lighting i guess for the pre that plugged there i guess,i measured them while ago,but the amp chassis also has an rca jack too thats tied in with the heater circuit ,i wonder why have one at octal and one at the rca? Wierd i guess ,a packard thing huhYou could just follow them back to where they came from, and clip, or de-solder them.
With the output tubes removed the voltages will climb above the operating voltage the unit is supposed to run, and could even be over the cap rating
Ok thanks ,i posted below in thread ill change those caps,im jus learning the wiring,reminds me of that tangled fake easter grass we got as kids to put in the basket lolThe can, if shorted, would only get warm with the 6CA4 tube plugged in. Without it, no DC so it can't do anything at all. Ok, let's clear some things up. At the moment you have 3 tubes, one 6AQ5, one 12AX7, and one 6CA4.
The missing 6AQ5 won't matter except that only that one channel will not work. If the can is shorted (I already think it is), then it will get warm with the 6CA4 tube ONLY.
Yep thanks,did what you said ,can see more now,i ended up with two unused green wires ,they are 6.8 volts,but did something with the preamp,the come straight from the transformer on my amp,the PT ,do i need to now run a virtual load on the wires now? Or cut and shrink,thanks again for helpingOne or some of those caps in the can might go to the external preamp/tuner through the octal socket. you might not need to replace that one if that's the case.
As you are moving forward, try to figure out that octal socket, if you can clean that up, and clean up the can cap area, you will have a better understanding of the circuit.
