Retrovert
Addicted Member
What's the result of the Tobin mod on the B301?
The Tobin modification has four components:
(1) Downwards moves the crossover points for the midrange and woofer from 800 Hz to 400 Hz (inductor taps)
(2) Balances the hotter B-200Y tweeter to the other drivers (attenuator resistor)
(3) Removes the attenuator at the upper end of the tweeters to increase SPL as tweeter falls off
(4) Un-reverses the reversed-polarity midrange so the polarity matches the other drivers.
The B-450 likely cannot be downwards moved to 400 Hz without hammering the low end of the midrange, so (1) is a non-starter. It might go down to 600 Hz as a compromise, but this would require a new woofer inductor and a new midrange capacitor.
The B-301 only uses a single tweeter, and (at least the CD did) has a brightness control, so (2) likely isn't needed as the equivalent somewhat exists.
Regarding (3), add a supertweeter (band-pass the existing tweeter and band-pass the supertweeter, as I've elsewhere described).
As far as (4), I believe that the midrange polarity was reverse wired in the B-301CD, but I can't remember with certainty. I'd have to find my notes. I remember checking the polarity when I was done rebuilding the crossover, but I no longer remember what it was when I began. I've extensively written about the benefits of unreversed drivers, and how Polarity Reversal ≠ Phase Shift.
If your midrange doesn't have a cover, add the plastic flowerpot as I've elsewhere described. That will prevent cross-modulation between woofer and midrange, and it dramatically cleans up the sound. Do one speaker, then do an A/B comparison using a mono signal. Night and day.
Is the performance of the sealed B301 any better or worse than the small ported Bozaks?
Eh, that comes down to personal preference. I would say superior accuracy, because porting introduces all sorts of inaccuracies from group delay which infinite baffle, by its very definition, lacks. But the lowest frequency reproduced is raised in the smaller cabinet vs the ported cabinet. Some consider that a drawback. I'd rather add a few subwoofers and be done with it.
The only experiment I know with the ported DMS-2500, a modern version of the B-201 Sonora with an Audax soft dome, was that plugging the port and lining the cabinet was an improvement over ported. The bass no longer went as low, but it was much cleaner at the low end. As I noted, I prefer a decent subwoofer to handle the lower frequencies with some accuracy than a ported speaker which sonic meatgrinders the remainder of the sound.
