I just recently picked up a Fisher Coronet console which contained an SA-16 amp and 100-T preamp/tuner and have a few questions about the SA-16:
1. Can someone explain the output tube bias circuit to me? It seems as though the circuit places 7.2V on the grid and 19V on the cathode. What's the purpose of elevating the grid voltage to 7.2V? Why not just keep the grid at 0 and the cathode at 12V like most EL84 cathode biased amps seem to do?
2. How do I measure the tube bias, do I just divide the voltage across R33 by its resistance or do i have to account for the 7V at the grid somehow? With a bias resistor of 125 ohms and 19V at the cathode it would seem that the tubes are dissipating more than 12W.
3. On the schematic what are the purpose of R31 and C13, which are connected to pin 4 of the shorting plug? Are they there to support a device that could be connected to the plug? If so, can I remove them if I plan to run the amp standalone or is it fine just to leave them be?
Also, as an observation it seems to me that with only a few resistor value changes this amp is pretty much identical to the 30A amps, except the 30A don't have the same bias scheme as outlined in 1. Hope to hear from all the Fisher fans.
