I bought off the bay a model 8 serial number: 222C1C975 in which it has 2 problems at first glance. First is the volume on the right side is way low, even with headphones. I knew this before buying it but thought maybe the controls need a good cleaning/lub. All lights work, speaker relay is quick to click, so that's good. The second problem is the dial string slips, what can I do about that? All in all for $42 plus S/H I think the reciever is in really good shape, the wood top has a few scratches but in fine shape. I'll invest some time and cash to get this Sansui up and running. If she sounds as good as I've read about 8's she'll be a keeper.
Btw, I have read about the Saucer shaped transistors which I can see from the top, how bad are these and do I need to start to make a list on replacing these along with all the caps? I really like to first get it up and running on both channels first. Thanks for all your help.
