There are two salient specifications to be aware of when considering the suitability of your amp/preamp combination: input sensitivity of the amp and the input impedance of the amp. Both these specifications are normally provided by the amp manufacturer. Input sensitivity is the input voltage that drives the amps to clipping, e.g. full output and input impedance is the load that the amp puts on the preamp. Check both specs. with the manufacturer of the amp.
If the input sensitivity is less than 1VRMS then you don't even need a preamp; a simply volume control on the amp would be sufficient to give you 6dB of headroom. The amount of gain in the preamp is only relevant in that in general the more gain it has, the more noise and distortion will be present in the signal, because there will be more stages for the signal to pass through and each gain stage adds noise and distortion, even if it is small. Here's the point: there are 2Vrms as standard output from a CD player and if your amp can be driven to full output by 1Vrms you can see that any more gain in the signal chain will be a complete waste and will be attenuated by the volume control. So if you have 2V coming from the CD player and the preamp has a gain of 10, you now have the potential 20V to be reduced by the volume control to whatever the input needs of the amp. In the example above that would be in the range of millivolts for typical listening levels. The point is that your preamp should be as simple as possible with the fewest stages possible or all the gain will be wasted in the volume control as added noise.
