New Tower Speakers
bernouski
hey all so i'm wondering what tower
speakers i should get for my hometheater/video game/music station.
ar the moment i'm rolling Polk 45b 3 way speakers and infinity rs3 that
have no foam. i want to toss the polks in the back where the infinity are
then purchase Polk 75T 4 way tower speakers with four 6 1/2".
Any suggestions?
Thanks for your time
my budget is $500 to $600 for a pair.
the space is 200 sq feet
a yamaha htr 4066 powers them
5-channel powerful surround sound
115 W per channel (8 ohms, 1 kHz, 0.9% THD, 1-ch driven)
80 W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2-ch driven)
First I would stop using the infinity speakers with no foam. Either repair them or give them to someone who will. You are ruining the voice coils and they will soon cease to play. The Polk towers you picked should match up fine with your other Polks. If you want a center, stick with a Polk in the same series as the fronts so that the voicing is the same. Any sub can be used as your needs and budget dictate.
thanks a lot for the reply mang, and for the tip about the foam, I'll quit using them immediatly.
Sorry about all the questions but are bookshelves really optimal for rear speakers? I thought the rear were supposed to be tiny sattelites. Will have bookshelves as rear not suck up wattage that the tower speakers or subwoofer need?
Thanks for your time all
It depends on what you want your HT to able to do. DTS in many movies actually recommends you use large towers at all four corners for proper sound. Dolby originally, if I remember correctly, assumed the use of small satellites because they were intended to be producing very small amounts of ambient information in a severely restricted frequency range so small was all it needed.
Along with that the Dolby receivers of the day had only a small amount of amp power for the rear channels. However as surround sound took off, this changed a LOT. With DTS emerging to challenge Dolby, Dolby responding with Dolby Digital, etc. things changed pretty quick. Now HT receivers needed full power in all channels to handle the requirements of all the formats and possible speaker combinations. So what started out only needing small satellites to handle the limited sound and frequency range now needed more power and larger speakers.
A good bookshelf speaker will potentially give you better sound if it has good wide dispersion characteristics. That's what helps sound that travels from the rear to the front or from front to back appear more seamless.
Dedicated satellites for rear HT applications can often have multiple speakers on 2 or three sides to improve this affect. Smaller satellites that don't have this, aren't from the same series, etc. can often make this worse than using a decent bookshelf would be able to do.
It all depends on how well you want it all to blend together. And it all depends on how willing you are to take the time to properly set it all up. Positioning is often crucial to hearing a really good movie sound it's best. Along with making sure all the settings in the HT receiver itself is right.
As far as a sub goes, it really depends on what you want it to do. There seems to always be a lot of cheap subs showing up on CL but if they will work in your system, match your speakers sound, much less actually dig down for tight, accurate bass in your listening room can be a crap shoot.
Do the research on line and at least get an idea of what you are looking for with your speakers. Double check the specs for your speakers for how low they can cleanly go and start there. Then look at different deals on line and research each model for reviews, forum threads either here or elsewhere, and check out it's specs.
The best you can do is spend some time digging in to your research. Educate yourself because that's the only way you'll know for sure you're hopefully getting what will work for your system in your room. DON'T be in a rush. Take your time and look around. It will pay off in the long run.
Looking at Amazon and Newegg, you can get the 75T for under $200 each and a Polk 25C center for under $150. That fits right in your budget and they should all sound good together. The towers should be good down to about 40Hz so you could probably hold off on a sub at least for a while. As was mentioned, you have plenty of power for the surround speakers. When you buy a sub, it will have its own power supply so there is no further drain on your receiver. Usually you cross the sub at about 80Hz (unless you are using small surrounds) to fill in for the low end deficiencies of the surrounds or if you just have to have that low rumble and big explosion. Usually, more money buys you a lower bottom range on a sub. Using two subs can sound better than using one sub that costs twice as much. If price is an object, you can pick up a good budget sub and add a second as funds allow. The subs do not have to match. When I added the second sub to my system, it improved both the sound and distribution of bass throughout the room.
okay guys and girls thank you for the tips
on audiophilia.
i think i chose a good choice by going polk
monitor series as my first speaker setup. i've
read everywhere that their product is the best
bang for your buck.
i'll stick around this forum to hopefully pickup
on more tips and info about HT setups.
again, thanks all for your time
edit:: i already have a pol PSW110-10 in. 200watt
sub 30hz
