Hi everyone,
I've finally managed to acquire a new to me kenwood kd-500 with a grace 707 mkII installed. I have not installed my adc xlm mkII cartridge yet but plan to this weekend. I've noticed a couple of odd things about the tonearm since getting the table home and looking at the grace 707 user manuals available on VE.
I noticed that there should be a rubber gasket/washer directly above the tonearm board and one directly below. Theres a plastic base plate on the bottom side of the tonearm board directly above the mounting bolt, which I see in the manual. I can't tell if theres a rubber gasket between this plastic base plate and the tonearm board but I don't think there is, unless its really thin. I assume these were provided for damping the arm, but will it be a big deal if they're not used? I'm sure I could find some sort of replacement, but I'd rather not disassemble the arm from the tonearm board if its not critical.
My next observation is that the outward most rod and weight (the gold one) on the antiskate mechanism are not original. The post has no markings that would be associated with the different antiskate weight settings. The sliding weight is gold, and I believe the original was matte silver. This is based on viewing many photos of the various editions of these tonearms on the internet. If anyone recognizes the original equipment that these replacement components may have come from, I'd be interested to know. If someone has a grace 707mkii arm and would be willing to unscrew that post and sliding weight to weight it and give me a mass of the original, that would be really helpful.
I'd also like to know if the counterweight assembly looks right and if the headshell is wired as it should be.
Looking forward to your responses!
Thanks,
Max
Thanks,
Max
