ChckenLeg
I just purchased a Boyuurange Reisong A12 EL34 12AX7 (ECC83) tube amp from Amazon. This is my first tube amp. I purchased this amp because it’s an upgraded version of the A10, the A10 received mostly favorable reviews, and several YouTube content providers recommended the A10 as a good amp for someone testing the waters as a first time tube amp owner.
I have only owned SS amps in the past so I don’t have a clue about the basic do's and don'ts of using a tube amp. Where can I find beginners info on how to use tube amps, specifically the do's and don'ts. For example, I have read that I should not power on the amp without speakers attached. As a SS amp owner, I would not have known that. It seems to me that I read somewhere that I should not touch the tubes with bare fingers when installing them. Also, I read that new tubes need about 30 to 40 hours of break-in time. Where can I find info on other do's and don’ts that I should follow so I don’t inadvertently damage the amp?
The A12 amp has an Auxiliary input and another input labeled as CD. I will be using this amp to play my Pro-ject Carbon Debut EVO turntable and my old Yamaha 5 CD carousel player. I have a phono pre-amp on order and I am guessing I need a DAC to connect the CD player. I will using this amp with my Klipsch Chorus II speakers in a 12’ x 17’ room and approximately 10’ away from the speakers where the speakers are about 10’ apart. The speakers are 8 ohm impedance and 101db sensitivity. I don’t listen to music as loudly as I did when I was younger so I am guessing (hoping) that the volume will be sufficiently loud for my taste.
Any advice or helpful links is much appreciated.
Thanks,
Chkenleg
Thanks,
Chkenleg
However, my phono pre-amp won’t arrive for another couple of days. I can still connect and play my CD player though. This will be my first experience with hearing a tube amp. I am not expecting to be wow'd with the stock Chinese tubes but I think I will have some of that tubey sound.
