I'm about to clean the pots and switches following the AK "Idiot's guide to DeOxit" but before I start is there anything in there i should definitely NOT touch?
Either do to risk of electrical shock or just because it could cause some damage or it's not worth the trouble?
I did a search on AK and did find some posts on discharging the caps:
"Make sure that caps are discharged. If you don't know how to discharge the main filter caps, I would suggest leaving the unit unplugged for a couple days before working inside it. Most units would discharge quicker than that, but some may not."
So if I just unplug it for a couple days all should be ok?
I'm assuming the larger black ones (see attached) are the power supply capacitors and could have a risk of shock?
Will those also discharge if unplugged a few days?
I just want to make sure I don't mess anything up or shock myself!
Mark
Mark
