nashvillebill
It sounds like the antiskating is out of whack. Turn the antiskating dial to 0, set the tracking force to 0. Make sure the tonearm counterbalance is adjusted so the tonearm "floats". If the antiskating is correctly adjusted, the tonearm shouldn't move. If it's out of adjustment, the tonearm will move outward--or if you tap it inward, it'll continue moving inward.
The adjustment is a spring with a screw, if i remember correctly, look under the TT at the antiskating knob and there's the screw at the end of a spring. Loosen the spring screw for less antiskating.
Also check and make sure the tonearm wires aren't pulling the arm out (doubtful) and make sure the TT is level.
Replenishing the tonearm dampening fluid is a PITA but not impossible, you merely have to take the tonearm assembly off. Took me about an hour start-to-finish on my 1225. (Follow the directions on the 1228 from vinylengine). I got the 500,000 cps silicone oil from a RC hobby shop, it's what they use in the car gears apparently (they sell different weights).
