Newby Question - those wrapped wires - how to remove?
rlordjr
I'm learning as I go with a 6160 receiver and want to test parts on the pre-amp board (I've got one weak channel and hissing). This board sits vertically and has long pins/leads off the board which go to the underside. The wires attached to each of these pins looks like it is just tightly wound around the pin (6 or 8 wraps I'd guess) but not soldered? Seems like to remove the board I'd need to remove these wires but I didn't want to just cut them off. Is there a trick to unwinding or otherwise pulling them off the pins in a non-destructive way? Are they actually soldered on? Thanks for any help.
They are just wrapped, not soldered.
There is usually a way to manipulate the board to work on it without disturbing the wire wraps. If you absolutely must remove one or a few, unsolder the pin from the board leaving the wire wraps intact then solder the pin back in when finished. Cutting the wire is a last resort and the result usually looks horrible
Dave Pike – Jazz For The Jet Set
Nature Sounds/US/2020
Bass – Bob Cranshaw (tracks: A1, B1, B3, B4), Jimmy Lewis (2) (tracks: A2 to A4, B2)
Drums – Bruno Carr (tracks: A1, B1, B3, B4), Grady Tate (tracks: A2 to A4, B2)
Guitar – Billy Butler
Marimba – Dave Pike
Organ – Herbie Hancock
Soloist [All Other Trumpet Solos] – Clark Terry
Soloist [Trumpet Solo] – Martin Sheller* (tracks: B3), Melvin Lastie (tracks: B2)
Trumpet – Clark Terry, Martin Sheller* (tracks: A1, B1, B3, B4), Melvin Lastie (tracks: A2 to A4, B2)
Marimba – Dave Pike
Wrong thread...
Thanks. unsoldering the pins looks easier to me
Wire wrap is an effective way to make an electrical connection. However, it is primarily used as a labor saving and quality control step for the manufacturer. Strip, place and fasten in just a few steps with one tool. When you are making 10,000 identical units, what’s not to like? From an electron flow standpoint it has no advantage over a well made solder joint.
I try to maintain the wraps where possible (and even own a wire wrap gun), but have no qualms about reattaching a wire to a pin with solder if it’s more convenient. I find that removing the pins with soldering iron heat can put stress on some boards.
BTW, there are wire wrap removal tools, but they are a bit expensive. They are usually on the end of manual wire wrap tools.
