I've been fretting over the first stage headroom in the 6L6GC UL amp I'm working on. Trying to balance quiescent voltage of the 12AX7 AF amp stage against the needs of the DC-coupled differential inverter and finding the most linear operating region of the 12AX7 has led me to setting the bias of that stage to -1V, which is only 700mVrms of input signal headroom.
Obviously, I don't want to overdrive that first stage, which on the surface seems like what's going to happen with basically any input source I connect.
But I do plan to use about -12dB of feedback, which, as I thought about it, seems to suggest that, because the closed loop gain of the stage is only 25% of that the open loop gain is, I can actually manage 2.8Vrms of input signal before the stage overdrives (which would be plenty of headroom for my needs).
Am I correct?
Am I correct?
