Thanks in advance for all the help from audiokarma.org.
This thread can be a all inclusive transistor replacement list for the Nikko-1415 receiver. So i am being thorough
I am replacing the transistors on the left channel main amp board of my Nikko 1415 175wpc reciver.
The damage was severe. The outputs shorted, some transistors fried, and some resistors burned up.
I want to replace all with new quality parts that work well together. Onsemi preferred where possible. Here is a list of the transistors and included is the schematic and some photos of the damage
I am replacing all the transistors , caps, trim pot and diodes as well as the bad resistors.
If you know of the proper replacements let me know - preferably new/readily available parts
Q701 2SA941 (BL)
Q702 2SA941(BL)
Q704 2SA941(BL)
Q705 2SA941(BL)
Q706 2SC2088(BL)
Q707 2SC2088(BL)
Q708 2SA817(O,Y)
Q709 2SC1627(O,Y)
Q710 2SD381(2) (M,N)
Q711 2SC1627 (O,Y)
Q712 2SC945 (L) (P,Q)
Q713 2SA733 (Q,R)
Q714 2SD381(2) (M,N)
Q715 2SB536 (2) (M,N)
Outputs
Q716 2SD555 (Q,R)
Q717 2SB600 (Q,R)
Q718 2SD555 (Q,R)
Q719 2SB600 (Q,R)
Q701 2SA941 (BL)
Q702 2SA941(BL)
Q704 2SA941(BL)
Q705 2SA941(BL)
Q706 2SC2088(BL)
Q707 2SC2088(BL)
Q708 2SA817(O,Y)
Q709 2SC1627(O,Y)
Q711 2SC1627 (O,Y)
Q713 2SA733 (Q,R)
Outputs
Q716 2SD555 (Q,R)
Q717 2SB600 (Q,R)
Q718 2SD555 (Q,R)
Q719 2SB600 (Q,R)
Sounds like motor boating (Low frequency oscillation). My best guess would be one of the electrolytic caps is bad. I'd start with 711, 712 and 701. Also check grounding, and keep and eye out for errant resistor. Good luck
