NIKKO 8085
Natalya
A friend of mine was impressed with how well my dad's old Pioneer SX-535 sounds after I fixed it, so he asked me to check out his Nikko 8085.
Here it is opened up. DeoxIT fixed all the sound issues. A couple channels didn't work and the left sounded all staticy, but after spraying all the pots and switches and turning // flipping them it sounds good. The sound is clear, even on AM and FM.
I did notice the tuning needle for FM doesn't hit the best sound in the middle. The best sound is a little to the left. Can that be adjusted?
The remaining problems are cosmetic. Here you can see most of the radio signal guide lights are dead. I hadn't seen these bulbs before -- I thought they were fuses at first. I'm not sure where to get these or what they're called. I pulled one out.
Bulb dimensions
Length: Approx 29mm or 1.1875"
Diameter: Approx 6mm or 0.25"
The bulb has 8V0.3A written on it.
There are also dead bulbs for the STEREO, FM, and PHONO lights.
This is the stereo light bulb. I've not seen this type either. A very gentle tug was all it took to tear the corroded guts out of it.
The caps all look really old, but it sounded fine, so maybe I don't need to touch them?
I was initially going to look at replacing and upgrading these bad boys, but again it all sounds good right now. DeoxIT did all the work for me!
The final cosmetic issue is all the knobs and switches have like little marks and some kind of brownish residue on them. Is there a good cleaning product I could try?
I'm told magic erasers work great for polishing up aluminum knobs and face plates. I would be careful around the lettering, though - the magic erasers are microabrasive. Not sure if they would rub off the text.
On my 9095 I just soaked the knobs etc. for a while in a bowl with Dish soap and used an old toothbrush to clean. They all should come off without difficulty.
The Fuse style Lamps are fairly common to that era. You can try auto parts stores or there's an AK'r who deals Lamps, can't remember his name but search DGwojo (?)
I think the Tuner Dial String on mine slipped over the years. Stations come in strong and clear so I just got used to 91.1 coming in at 91.3. If Stations are not coming in clear it might need an alignment.
I used a red LED to replace the disintegrated stereo bulb.
I've also ordered the fuse lamps for the other bulbs.
Just wanting to update that I got the fuse-lamps replaced with part # 070-120 from Parts Express.
https://www.parts-express.com/8V-250mA-Fuse-Type-Lamp-070-120
They're not exactly the same specs as the originals, but they look nice. I replaced all of them at the same time, in case the other older ones were ready to die soon.
I also replaced the FM and PHONO lights with yellow LEDs, similar to my replacement of the Stereo bulb. I put it all back together and it looks good!
