Nikko Alpha 230 unknown outputs
philster
I got this Nikko 230 with a blown left channel. The outputs tested bad (2SA1095 and 2SC2565)as well as the drivers (2SA985 and 2SC2275). The bias transistors were bad as well 2Sd882 and 2SB772. Continued testing revealed several burnt resistors and transistors in the bias circuit. The resistors were replaced as well as the transistors in the bias circuit. The drivers were replaced with 2SA1220 and KSC2690 including the ones on the right channel. The bad outputs have all been removed on the left channel. I did a power up thru the DBT and got a good relay engagement. I only have one pair of outputs that were pulls and need another pair or a viable replacement. One pair of the outputs I pulled were not originals. I have never seen any outputs with these markings and curious to know if anyone else has seen these before. In fact I wonder if these is what caused the left channel to completely burn out
ERS 33/34 are likely close equivalents. If they test shorted(bad) just replace with the Toshiba 2SA1095 and 2SC2565 equivalent subs. May have to go with a TO-3P case. :idea: Those OEM Toshiba's have long been extinct from Toshiba production. Anything on the internet from China are likely candidates for counterfeit. Buyer beware. ;)
Thanks for the info, its been awhile. SO far I have come up with NJW0302G and NJW0281G. In another thread 2SA1386a and 2SC3519 are suggested but digikey has them to order in 1000 increments and that aint happening here. I dislike that when they do that.
My Japanese substitution manual gives the much more easily (genuine) found Toshiba 2SA-1302 and 2SC-3281 as subs. You may have to make a aluminium 'bar' with two holes to mount them, or drill a single hole.
Outputs came in. I replaced all fried outputs including the bias transistors. I get nothing on the idle adjustment. I have a 8 ohm dummy load connected to the speaker outputs. Looking at the schematics there is no voltage notations. From my very novice experience the bias circuit looks very common but I need help as to where to start taking measurements
Did you ever get this sorted? I have a 230 and I think the outputs may be shot. It’s in protect.
I installed new outputs and it comes out of protection. The new problem is not being able to set the bias. Bias reads 0vdc so i am not getting current flowing thru the bias circuit. When I got this amp it had some off the wall outputs installed on the left channel and in turn it completely fried the left channel which now I believe was a result of a over bias issue. I had to replace many burnt resistors and transistors on the left channel. The nice thing about this amp as well as many other Nikko amps each channel is mirror image of the other which makes troubleshooting much easier especially when one channel is still good. I was able to source original outputs, Although they were used they still worked like a charm. Pay attention to the layout of the outputs. The amp is kind of a pita ass to pull apart. You'll have to test the outputs to see which ones are bad
First off thanks for replying. I’ve been testing most components in the protection circuit but so far everything test fine. Testing the outputs “ always” confuses me with the DMM. I just can’t seem to grasp a simple method of the whole probe to pin and resulting readings.
It can be but I find it useful to have a step by step guide handy when testing. Avionic put together a nice guide for testing transistors. You can even Google transistor testing with a DMM and get some useful videos. I spent the money and got a good transistor tester and it makes life a little easier, Remember when testing the outputs to desolder them from the board first for an accurate reading
