Fred DuBuron
Recently picked up a second Niko Alpha 230 (1987 model) and it has a burnt-out Panel illumination bulb (8V 0.3Amp). The power LEDs work fine but the edge lighting is out. I have heard this bulb may not be available in its original configuration and was looking for advice on the best way to proceed.
My other issue is my original Alpha 230 (1983 model) has a calibration voltage issue with the Power LEDs... Idles with the first two LEDs lit. I currently do not have access to a sig generator to feed into the unit to adjust the power settings for the LEDs. What options do I have?... It performs well and sounds fine as is.
