translations please!
I got this and a Gamma I tuner so my Beta II pre amp would have company...
anyway, after unpackeing (broke a sweat!, great job by an ebay seller!) I let the two run for about an hour unloaded and noticed the amps left channel was warmer then the right channel. I have the manual and it has several adjustments listed that look to be easy to perform BUT, just for my clarifiacation, I have mid point voltage adjustment and idling current adjustment. What translates to DC bias? And, should I make these adjustment in any particular order?
BTW, the manual also says I need to attach dummy loads to the L & R speaker terminals. While making previous adjustments on my gear I have not had any loads attached. Is this proceedure particular to Nikko?
Thanks in advance!
Thanks in advance!
