If philster in forum DIY is you... I went back through your 2024 Nikko Alpha III repair thread on DIYAudio, where Mooly helped you troubleshoot the voltage regulators. There's some useful information there that applies directly to what we're seeing now.
In post #22, Mooly explained how the Zener reference and the 33k/22k resistor divider determine the regulated output voltage.
Using your current Zener readings:
- ZD815: 22.1 V → approximately +56.8 V regulated
- ZD816: 21.3 V → approximately -54.8 V regulated
These are the approximate voltages we should expect if both regulators are operating normally.
Nikko Alpha III that I can't set the idle current on
More importantly, in post #35, Mooly explained that the regulators should maintain approximately ±56 V with around ±65 V or more at their inputs.
And in your own post #43, on November 6, 2024, you reported approximately ±66 V at the collectors of Q815 and Q816, with around ±55 V at their emitters. So you had both regulators working properly under the DBT on that Alpha III.
Now, on your current Alpha III, we're seeing only ±61 V at the regulator inputs, with the outputs following at the same voltage.
With the 75 W bulb limiting the incoming supply, we may simply not have enough voltage for the regulators to operate properly.
I'd like to establish whether we're dealing with insufficient input voltage under the DBT or an actual regulator fault before replacing any more components.
If philster in forum DIY is you, did you happen to record what wattage bulb you were using in your DBT during that 2024 repair? Have you been using the same bulb ever since, or have you changed wattages over the years?
That would be useful to know, especially since you were able to get both regulators working at approximately ±55 V with ±66 V at their inputs back then.
