No FM or AM in SX1050
qguy
Hi
My SX1050 FM or AM does not work, it was intermittent before and now its totally dead.
When press the multipath or the FM mute it makes a sound like when there is no antenna
all switches has been cleaned
AUX works with an external source.
Thanks in advance
Switches and controls cleaned with a solvent or deoxidizer liquid need to dry thoroughly before they can be expected to function normally.
Check the power supply feeds for the tuner board. There could be a loose wire: Or the ground wire from the tuner board. I checked the manual on HiFi Engine for the print. Three supply leads. (Longshot I know, but worth a look)
I check the wires all are intact and connected.
This issue would have to wait, got "bigger" issues at the tone/filter control boards :(
Checking involves a voltmeter at tuner board connections - visual inspection is only the warm-up...
