SERGIObisont
Hello all.
My receiver is working perfectly, except one anoying thing: Tuner is working, I can tune stations and save them on memory.
But RDS is not working! there are no stations names or info. only the station frequency.
Also, when Im memorizing the stations, the memory button becomes iresponsive after about a minute..
But when I go on 'test mode', RDS is working perfectly and I can see station names... also, the memory button is always responsive (but does other strage stuff in test mode). Already did the reset to factory, but its the same..
I have seen somes threads about the memory super cap, and some capacitors on that area causing some problems on 'normal mode' when there are no problems in 'test mode'.
hope someone can help me
thank you
thank you
