I'm hunting right now for some good but affordable 5751s. Any recommendations? Btw, is this transformer ok to turn down the voltage to 110v? Thanks again.
Yinleader 500W Voltage Transformer Power Converter(220V to 110V, 110V to 220V) Step Up/Down Converter 110/120 Volt - 220/240 Volt
https://www.amazon.com/dp/B07PS3NKWS/ref=cm_sw_r_apan_i_9TJAYNNY9RRJHYF80G1X
No, that unit would be used for running devices made for standard American voltages in countries where the nominal wall voltage is 220v and vice versa.
There are various devices that reduce the wall voltage but not all of them actually regulate it to a stable voltage, even if they're sold as "voltage regulators". Some, when set to their "110v" setting can actually put out voltages that are over 110v. This might still result in heater voltages that are on the high side.
The cheapest way to get the heater voltages in line is to add some low value resistors. You would need to measure the heater voltages with the unit plugged into your wall first, and also measure the actual wall voltage. The wall voltage will vary a bit but if you measure it several times a day for a few days you can get an idea of how high it can go. Then figure out the value of the resistors you need from there.
When I build things I set my variac so that I have 122v coming into the unit and I use whatever resistor values are needed to get the heater voltages right with that input voltage, which is typically what I have coming from the wall.
I've never heard a 5751 that I didn't like but they've all been old production American tubes. I believe there are some new production 5751s but I have no idea how good they are. And, given the current tube supply situation, who knows how affordable they are even if you can find them.
Make sure to replace the 12au7s with good tubes. The stock 12au7s seems to be the culprit in making this preamp sound crappy. Right now, I have nos 12au7s with stock 12ax7s and it's sounding more detailed and opened than my NADs.
The 12AU7s, as used in that preamp, are cathode followers and I would think that they have much less effect on the sound than the 12AX7s. However, based on the results of that shootout, this preamp doesn't really have any "tube sound" worth mentioning. So, to me, it doesn't make much sense to spend money on tube rolling in a preamp that doesn't exhibit any "tube sound". It may be an improvement over your SS preamps but that's not saying much.
I think
@CraigVMN did the smart thing by cancelling his order. If you want to try a Chinese tube preamp, why not try the one that
won Stephe's shootout? Not only does it sound better, it's a fraction of the price of the Nobsound.
