Noisy 9090 Transformer
BearsFan
Hi All-
I just had my 9090 restored by Chris in Pa - beautiful job. :banana:The power and bass have come back to their former richness, overall a great job. One issue, however, remains.
This unit has had a noticable transformer hum for the two years I've owned it. It's audible when the room is quiet and it is not transmitting to the speakers. We didn't have a replacement transformer at the time of the restoration and had hoped the hum was related to the overall power supply loading - this unfortunately wasn't the case. It's more an annoyance than a functional issue, but I'd like to resolve it.
Since the restoration, the transformer is running much cooler than beforehand, so other than the hum, everything is functioning like new.
Question - does anyone have access to a tested 9090 transformer? The number I have in the schematic is 4002350. There's also a 8080 transformer, 4002340 shown on the same schematic. Are these transformers physically the same (interchangeable)? I do have access to a junk parts 8080, but I am not clear on compatibility.
Any feedback hear would be greatly appreciated!
I believe the 8080 and 9090 transformers are different. The hum you hear is probably nothing to wory about. As long as it works, I would leave it alone.
Thanks for the feedback - as far as the photo, I can do that but I will say they do look the same physically but they do have different part numbers in the origianal parts list and on the schematic.
Paul79, just to give you an idea of how much hum there is, you can feel it through the tuning knob when you put your hand on it. I just don't want this beautiful restoration going up in smoke! Chris really did a beautiful job on this unit - from a power perspective, 8-9 o'clock on the volume is full and loud, and the bass is full, all tone switches at neutral, no loudness button required! This unit had a definite absence of bass pre-restoration.
I am now sold on this procedure if you plan to keep the unit, it really makes a difference.
Get out your wrench
Hi All-
From your description of the hum I'd suggest that you need to torque the 4 bolts on the power transformer. It sounds like the plates are loose. This is not uncommon in power transformers. When they get loose from endless heating/cooling cycles, the 60 cycle magnetic rise & fall causes those plates to vibrate. They are supposed to be clamped tight.
One other fix if tightening doesn't completely eliminate the hum is to shim any gaps in the plates with thin wooden wedges. But first, lets tighten those bolts. :thmbsp:
Paul
I am more interested in the physical characteristics of the xformer..The hum is caused by a loose lamination in the transformers laminated iron core or it could be just a loose transformer chassis mounting hardware..My moneys on the lamination..Ive had some luck with recoating the laminations with epoxy resin to resecure the lamination if...One has access to the transformers core frame. If the xformer is of the potted varity that makes things more difficult. Judging from the 8080s PS versus the 9090-the 9090 has a higher voltage output...So the 8080 is not a good candidate for cannabilization.
Yes indeed if the xformer has the 4 bolts by all means torque them down to 12-15 inchpounds or so. Don't over-torque! Snapped bolts really ruin your day.
Dave
The 8080 and 9090 transformers are physically and electrically different. The 9090 transformer is much larger and has higher voltage and current ratings than the 8080, they are not interchangeable:no:.
You may get the hum out of the transformer by tightening the bolts. If it doesn't PM me I may have a solution for you.
Hey all -
Thanks for the feedback - quick question, when you state the 4 bolts, I am assuming the four bolts that mount the tfr. to the chasis, not bolts that hold the tfr. together, correct?
The four bolts that mount to the chassis are right there as far as i recall, there are no obstructions.
Didn't even think about the mounting bolts, just kind of assumed this was done during restoration, which included tearing the whole unit down washing everything and reassembling after the recap. It's still worth checking, and I will inn the morning.
In the event it is the tfr, are there sources to get replacements or only boneyard units?
Thanks again to all for your help!
Nope, we are talking about the bolts holding the transformer together. Just be careful tighting.
Hi All-
Did he "rebuild" the power switch? I'd bet he didn't.......and the switch is the cause of your hum!
In the great cap debate I explained the increased current draw from old/weak capacitors........this increased current will pit and melt the contacts in the power switch.........which directly powers the transformer primary.
Poor contacts there will result in the transformer humming as described. I used to see this problem in the QRX-9001's I restored. Since seeing the problem, I routinely reverse the contacts in the power switch and have never had a problem since.
QB
I've had a 9090DB and an 8080DB with transformers that hummed. No amout of bolt tightening changed the sound. They would hum even with all the output leads disconnected from the power supply board. In both cases, I changed out the transformers and in both cases there was no hum with the replacement transformers.
- Pete
I am more interested in the physical characteristics of the xformer..The hum is caused by a loose lamination in the transformers laminated iron core or it could be just a loose transformer chassis mounting hardware..My moneys on the lamination..Ive had some luck with recoating the laminations with epoxy resin to resecure the lamination if...One has access to the transformers core frame. If the xformer is of the potted varity that makes things more difficult. Judging from the 8080s PS versus the 9090-the 9090 has a higher voltage output...So the 8080 is not a good candidate for cannabilization.Yes indeed if the xformer has the 4 bolts by all means torque them down to 12-15 inchpounds or so. Don't over-torque! Snapped bolts really ruin your day.
Dave
Thanks for the information. Epoxy resin . My pioneer A-7 suffers from the same buzzing sound which gets louder after an hour with the volume on zero . The sound comes only from the power transformer not thorough the speaker s .I opened the outer case of the PT and poured hot varnish while the transformer was hot too back in mid 2013 and all buzz sound was gone ,but now the buzz started again last December 2017
Epoxy resin is a good idea? . I have two epoxy resin which needs to be mixed together . Used them for my speaker woods as they were expanding . It's done a perfect job i attached a pic IMG_20180216_205605149.jpg
Al Manama.. Been there a couple times. I was stationed at Al Khobar just across the bridge. Hot and sticky humid.:biggrin:
I think you would want more of a liquid epoxy. It would be more likely to soak into the transformer laminates. This type of epoxy is used for coating and fiberglass.
- Pete
- Pete
thanks for your recommendation . Like what type exactly? like for what are they used generally so I can buy something similar to what you are referring to.
Google "laminating epoxy." There are many sources for it. It's typically used for laying up fiberglass. It's liquid like water but sets up very hard. The intent is to coat the windings and internal core lamination. Like avionic said, you have to dunk the whole transformer in the stuff. This is not an easy process.
The noise won't hurt anything but your ears. If it really bothers you, it would be easier and maybe even cheaper to find another transformer.
- Pete
Submerge it in resin and pull a vacuum on it.:rolleyes:
Thanks
- Pete
thank you very much
