Just tried to make som DIY xlr plugs. When i plug the male connector into the amp it makes a noise when i touch the plug itself, its like a ground loop noise, and its there when i touch both the male and female plug.
I have checked the pins and theres no connection between any of them or the plugs itself, so the plugs seems fine.
I have soldered the ground to pin 1, the hot to pin 2, the cold to pin 3 just like normal on both plugs (female and male).
Is the noise normal for some plugs when you touch them? The cable Is fine as long as I dont touch the plugs.
