noob c220 "balanced in" question
dave herzog
i know this is stupid, but i've read so much that now i'm confused: could one hypothetically connect a device to this preamp via balanced ins, and then listen to it through the UNbalanced outputs to poweramp and beyond? you can, right?
a related question: do you lose any of the unbalanced inputs if you use the balanced inputs?
thanks, sorry, etc.
To your first question: You can do that. There are balanced to unbalanced converter circuits in the preamp.
To your second question: I'm not sure on that one but I suspect that you can use both sets of inputs. I am using my experience with the C2200 to try to help out. Perhaps someone with a C220 will chime in.
Cheers,
David
As far as ballanced inputs on the C220, you have 2: CD & DVD
You have 8 unbalanced inputs, including phono, but you can't add them to get a total of 10, if that's what you're asking. You can't have different sources plugged into the CD unbalanced and balanced inputs.
Hope this answered your question...
it did, and thank you to both of you! cheers.
