Patrice B
Hi,
Back in the autumn, I bought a Nordmende Menuett Stereo as documented here:
http://www.audiokarma.org/forums/showthread.php?t=251263
Since day one, there's a difference in tone between left and right (so it was there before the restoration). Left is beefier than right, more bassy and the most important, more distorting. Just to precise, there's also distortion on left...
One would think that a complete restoration should cure the sound (including me) but for the first time in my case, serious problems remaining.
So, after a complete restoration (selenium, filter caps, all caps and almost all resistors, new tubes everywhere, deep cleaning of sockets and controls, double-check of the solder traces on the PCB's, reheating all solder, verifying each connection and value...), it sounds like crap to my point of view: I can't put too much volume or too much bass before it distorts, more on left than right.
A lot of questions:
1- Is it supposed to sound like this (I'm sure the answer is no but...) looking at the weird way it is built, meaning half an EABC80 (6AK8) for left preamp and an EBC81 (6BD7A) for preamp right? The schematic is linked at the end...
2- Do you see something obvious I could had missed during the process?
3- Is it possible the OPT's are saturated (or simply going south)? They're built a strange way: the two OPT's are in one physical part...
I'm not so bad when the time comes to read a schematic and replace parts to original specs... but I don't understand how and why those values or components are chosen instead of others. To resume, I do not understand really well the theory behind the circuitry.
For the record, I suspected first the internal speakers but it sounds like this on a spare set. It is the same, for FM, AM or any band and phono also (I installed a set of RCA plugs going in the tape in, TB on the schematic).
BTW, if it is of some interest, I had to up the value of R200 at 750 ohms to get the correct voltages after the rectifier.
If no solution come to my mind soon, I plan (maybe) going directly from the tape outs (I guess pins 3 and 5 on TB connector) to my Fleetwood little console amp... Finally, putting together a good sounding console amp without a working radio section (the Fleetwood) with another one (the Nordmende) missing a good amp/preamp section but with a good tuner.
This way, I would preserve the beautiful look of the furniture and I could use the original tuner (it seems to work fine on the tuning/sensitivity side) and the original speakers.
Thanks.
Patrice
linked schematic:http://cid-21651cbc33527896.skydrive.live.com/self.aspx/Public/3^_616^_s.tif
A lot of questions:
Thanks.
Patrice
