Nova 8bs - add more insulation?
smead
AK Subscriber
When I broke the cabinets down (they were trashed from moisture damage), I noticed the designers at the shack put insulation in the bottom around the woofer only. The top half of the cabinets above the baffle brace are empty.
Was this a conscious design choice or were they just tight with their insulation? Is stuffing the entire cabinet always better for an acoustic suspension design?
I'm almost done with an interesting project. I got two pairs of these, both with perfect drivers, but shot cabinets. This first pair is having the original Nova 8b baffle dropped and sealed into a pair of similarly sized Sansui sp 2000 cabinets I had and just restored. The Sansui's have slightly thicker cabs, a hair taller, wider, and deeper, but overall the internal volume should be just slightly more than the 8b cabs. They should look very nice, and I'm expecting them to sound quite good. I plan to brace the baffle, and was going to stuff the cab full of insulation, but was just curious if there was a reason for the original cabs being half stuffed.
Thanks!
I just worked on a set of 7b's.
They seemed to be overstuffed to me.
There was 9 squares of fiberglass batting in each cabinet, I felt like 4 was enough! I went ahead and reinstalled all 9 squares (they are about 9-10" square and 3-4" thick each square). They definitely filled the entire cabinet from bottom to top, no settling would occur.
Interesting. These 8bs are only half stuffed, and I can tell nothing has settled. I'm sure they had never been opened up.
So should I pack them tight?
Would love to hear from other 8b owners if yours were the same.
When I recapped and replaced the dead tweets on my 8Bs I seem to remember they had quite a bit of insulation. I doubt it will make much of a difference either way if you want to put more insulation in. The tweeters are in plastic tubes so I imagine that is why the RS engineers (and yes, RS did make their own speakers in factories in the Far East) did not worry about totally filling the cabinets to the top.
Ya, they should have been stuffed top to bottom. Someone had been inside those before, or someone goofed up at the factory. Even the Optimus 2B's I still have and the Optimus 1B's I used to have were stuffed full of fiberglass insulation. I would try to use as close to the same density as possible to restuff them.
I disagree with Lavane, I have a set of 7Bs and a single 8B, all 3 only have stuffing around the woofers. As far as I can tell, these were never opened up prior to me.
Thanks for confirming that, indeed mine are only stuffed around the woofs.
So I guess I'm back to my original quandary of deciding whether to stuff the new cabs full or just around the woofs like the factory did.
I doubt you will notice any difference.
Maybe changes were made in later production?
Probably more to do with the amount of fiberglass laying around the factory. Some weeks they probably felt they needed to reduce to have enough, some other weeks it probably seemed like they had too much, so they stuffed more in.
Nobody wants to deal with unused fiberglass, better get it all into the product!
I suspect that the amount of stuffing either reflects different drivers during production or different acoustic goals of the designers. While true acoustic suspension speakers need to be fully stuffed, many sealed enclosures are actually infinite baffles and the amount of stuffing depends on what amount of bass bump is intended.
I can say from experience that over damping produces a dull sounding speaker, but I suspect that getting the damping just right requires a lot of trying and listening.
I also suspect that, if all the damping material in an enclosure is the same, probably it was original - those inclined to tamper with the original design don't always have the same materials available as did the maker. That still leaves the possibility that some was removed, of course.
