flavio81
Turntable technician
I have found subjective terminology quite reliable.--more reliable in fact than measurement when trying to understand how something is actually going to perform and if I might like it. As most people know, equipment that measures the same, rarely (if ever) sounds the same from model to model or manufacturer to manufacturer.
So from this perspective, I'd argue that subjective "wine tasting" type information is much more useful and reliable than only reading measurements when it comes to choosing audio equipment. After all, I buy it to listen to, not to run my test equipment with.
There is a problem when we say "measurements". If when you're saying "Measurements" you mean the "wow, flutter, rumble" measurements done in the classical way (or even worse, as quoted by the manufacturers) then they are almost meaningless (unless the figures are not so great... Rega RP1/Pro-ject budget turntables anyone?)
But once upon a time, some magazines did make meaningful measurements such as platter/tonearm resonance spectrums, flutter spectrum, rumble spectrum, hum level, real-life distortion results, etc. And then, afterwards, yes, it is good to read a description of the subjective sound quality, IF the reviewer uses meaningful terms and not stupid babble such as:
"great toe-tapping potential"
"better pace"
"better rhythm"
"better timing"
"using record X, the sustain of piano notes were longer on this turntable versus the same record played on turntable Y "
Personally, i HATE all-subjective reviews. You CAN objectively measure sound quality. But the typical wow/flutter/rumble DIN/IEC/JIS measurement doesn't tell you very much about sound quality. Unless flutter goes near and over 0.1% in which case you can be assured piano notes will sound very unnatural.
As AK forumer Zilch said: "More data, less wank." when referring to speaker reviews. It's very different to see simple speaker specs (such as frequency response) versus seeing polar dispersion graphs and a cumulative spectrum decay ("waterfall") display done independently by someone like Zilch. Now those are VERY meaningful and relevant to sound quality. Speakers that sound well measure well when the meaningful measurements are done. It's just the same with a turntable because it's just a machine, a transducer. Sadly it's a transducer that is too often misunderstood.
More data... les wank! RIP Zilch.
