Observations of the Yamaha P2350
M Jarve
Audio Geek and NGE Freak
When I first started getting into the 2-channel hobby, much of what I used was pro-gear. Indeed, for some time my main 2-channel system consisted of Peavey 1210-H speakers, a Peavey CS-400 (and later CS-800) amplifier, and a Mackie 16-channel mixer, among other things.
While much of the stuff of that sort sounded good, it was not proper hi-fi as many of us know it. Pro gear, while being unusually robust and/or powerful, often trades out the lowest levels of detail or imaging, adds noise, or is noisy itself (cooling fans, humming transformers, small ground-loops, etc). This is all perfectly acceptable for sound reinforcement duty, where it's doubtful any "critical listening" is taking place, but, in a home environment, where I really only perform critical listening, it's distracting and becomes an issue.
So, long ago I traded away my huge, powerful amps for ones that had greater finesse, if not as much power. Large, highly sensitive speakers that required only a handful of watts to fill a large room over a limited range were given over to ones that require scores of watts just to wake up, but provide 20-20k frequency response and excellent mid-field imaging.
All that said, there is still space in my heart (and rack) for something that performs well and has the power and reliability of commercial kit. Yesterday, as I was enjoying some shopping in Duluth, I stopped by the Music-Go-Round and saw that they were selling a bunch of amps for a really good price. Among them were the above mentioned Peaveys, as well as units from QSC, Crown, Crest, and Yamaha. Indeed, they even had the "commercial" version of the M-4 for sale at a mere fraction of the price of it's home hi-fi sibling. As you might expect, much of this sort of secondhand pro-gear has been around the block (or several blocks), and the trade-off can be intimidating: of course scratches and gouges are in attendance (and in abundance); often times jacks are broken or even missing; knobs are missing or broken; and sometimes the gear stinks of cigarette smoke and booze.
Out of the pile of amps they had, I chose one that seemed to have suffered less in its life than the others. The fact that it also had a good reputation for quality sound and reliability was a welcome after thought.
The Yamaha P2350 is a pretty straight-forward power amp of the sort cherished by ammeter roadies. The front has a power switch and L-Pads for each channel, accompanied by status LEDs (signal and clipping). The back is a bit busier, with both TRS 1/4" and XLR quasi-balanced input jacks (a second set of TRS 1/4" jacks are also provided for loop-through support). Output jacks are standard 5-way binding posts.
Power-wise the model number says it all: Two channels, 350 watts between the two of them (175-watts per channel). Power output boosts to 250-WPC into 4-ohms, and the amp is apparently stable into loads as low as 2-ohms, though no specification is given. Being a pro-amp as it is, the unit can be bridged for mono operation, providing 500-watts into an 8-ohm load.
Before slotting it into my system, I stopped by MarkB's place to show off my spoils (and spin up a couple LP's I bought at Electric Fetus), and, as you might expect, being a collector of all things Yamaha, he had the service manual for my unit filed neatly away. Good thing, too, as I would simply have guessed at the proper calibration of the unit.
Once I got home, before slotting it into my system, I performed my now routine series of tests on it. This mostly establishes that the thing works and won't cause a catastrophic event the first time I use it.
DC offset was admirably low (less than 20mV deviation in either channel, improving as it warmed up), and the bias was off only by a bit. Power output with a 1kHz signal into a nominally 8-ohm load peaked out at a better than spec'd 192WPC channel (39.19VRMS), both channels driven. Into 4-ohms, it was just above the rated output at ~252WPC (31.75VRMS). Not extraordinary, but decent. At 2-ohms the power hit just shy of 287WPC (23.94VRMS) before it went into protect mode. Since, during the tests, the heatsinks never became even warm (staying at abient room temp) I think that there may be a current limiting circuit that keeps the amp from dying. Additionally, the output on the o'scope showed no sign of clipping before the amp went into protect mode during the 2-ohm test, indicating that there is current limiting going into play. In any event, the amp is usefully powerful for almost any purpose. As an aside, I did not test the amp with only a single channel driven, nor did I test it in bridged mode.
Construction-wise, the amp is pretty run-of-the-mill pro-amp. Most of the chassis is heavy sheetmetal, but in an novel twist, the heatsink assemblies form about 2/3 of the bottom of the chassis. The heatsinks are not themselves exposed, and are cooled by a set of 2-speed brushless DC fans, one for each channel. Internally, the central portion of the amp is dominated by a largeish 900VA EI core transformer. Towards the center-back is the input array, protection circuit, and additional power supply elements. The transformer feeds a large bridge rectifier, and power is smoothed by a single set of 15,000uFd caps. I've noted before that pro amps tend not to have substantial power reserves in the form of large banks of high-value caps, relying instead on larger, more capable power transformers meant for more continuous, high-power output (as opposed to many home amps, which combine a somewhat less capable power transformer designed for lower continuous ouput, but large amounts of capacitance to better handle dynamic peaks).
The amp circuit for each channel is a pretty basic affair; Output devices are a triple pair of 2SA1492/2SC3856. The output board and circuit is shared with the more powerful P2700, with the addition of 4 more output devices per channel. Indeed, by completing the output circuit, and installing the larger power transformer (and filter caps) one could conceivably upgrade the P2350 to a P2700. But, given that under ordinary circumstances the P2700 only costs $50 more, the value of doing so is questionable.
While I had it on the bench, and since I had the cover removed, I decided to disconnect the cooling fans. When the unit was powered on and idling, the fans were noticeably loud (akin to having a typical desktop computer powered up). Despite the enclosed design of the heatsinks, there seems to be adequate surface area as well as venting to alow this. After 2 hours of typical usage, the temp of the heatsinks hit only about 110-degrees F, so I'm pretty sure I'm in the clear here.
After going through the amp, calibrating it, measuring it, and so on, I slotted it into my system. First I used it full- range, then in various bi-amping configurations.
Full range, the amp performed well. While it does not have the ultimate resolution of my h/k 775's, there was no area that I could really find a fault with. If anything, its performance seemed a little on the polite side, given it's pro-grade status, but it did not seem overly reserved at all. Power to the speakers seemed plentiful and solid, with little sign of anything breaking down as high levels were reached. Occasionally the clipping lights would flicker, but you would be hard pressed to say that the amp was audibly clipping at that point. Imaging was so-so. Not super terrific, spooky-good, but not as bad as many other amps I've had. Mostly there was a lack of depth of the sort that I'm used to. Depth is a hard thing for amps to get right, in many occasions, but I can forgive it. L-R spatial cuing was as good as most amps, but the image did not often journey beyond the boundaries of the speakers. Tone seems to be dead neutral, leaning neither warm nor cool, and extension on both the low and high end seems to be very good. There was indeed a wonderful sense of "air" from the amp that I've not experiened with other pro amps. Bass extension also seemed to be quite good, but in terms of impact, it did not seem to match the h/k's, which is also not my experience with other pro amps.
Switching things around a bit, I put the system into a bi-amp configuration, but not crossed over at the line level, instead continuing to use the speakers' own crossover and running the amps full-range. While this is not as theoretically optimal as a full bi-amp setup, it does alow for a bit better dynamic range.
First I setup the Yamaha to power the mid-high end of the speakers (the drivers covering from ~200Hz on up), with the h/k's powering the Watkins woofer. This configuration gave me quite a bit more headroom and impact, but the fair to good imaging capability of the P2350 quickly became apparent. When run full-range, the excuse could be made that there was a lot more going on, but in this instance, the Yamaha showed its own capabilities were the limiting factor.
Swapping things around, putting the P2350 on the Watkins and the h/k's on high, proved to be the more optimal configuration. The setup gained a bit more "slam" in the bass regions, while retaining a coherent and high-resolution performance. The most surprising thing about this configuration, though, was that the P2350 seemed to sound just like an extension of the h/k 775's. There is no sense that "this amp is doing this and that amp doing that". I was indeed quite delighted by this observation. Very coherent perfomance between the amps.
Clearly, more listening is indicated, as well as a more thorough assessment of the amp's performance at low volumes (I've been cranking the system almost constantly). Additionally, I'm going to have to get a second set of ears in to verify my observations. But, I'm very pleased with the performance nonetheless.
Pictures (Inside and Out) possibly to follow.
The P2350 is a little past the PC2002M / P2200 glory days but it is still a good amp. Agreed, it is a good all around performer. Agreed, it does not have the ultra-wide band response of the HK but them few amps have the objective accuracy of the 775. HK's from that era can pass a 20Hz square wave better than a PC2002M, which is saying a lot. In fact, the PC2002M 20Hz trace exhibits slight tilting although the attack and decay are vertical and quite good. IIRC, the 775 has flat 20Hz top so the tone does not trail off.
I may comment further that amps with excellent objective accuracy can be interpreted as sounding tight compared to a slow amp that blurs bass notes and gives false and inaccurate expansion. Tight bass and big bass are both valid subjective preferences.
Well, with more listening put in, both solo and partnered with the 775's, I think I've rounded out my opinion on the Yamaha.
First off, it's not comparable in terms of sound quality with the 775's, particularly in the bass areas.
One piece that illustrates this particularly well is Bjork's Hunter. The synth bass line, when played through the 775's is crisp and very well defined. As it changes tones, the change is pronounced and obvious, and when it plays the very lowest tone starting at about 1:48 into the song (not so much heard as felt as a rapid change in air pressure in the ears), the 775's reach into their reserves and manage to play it with their accustomed sense of ease and effortlessness. With the P2350, the synth-bass line of the song is much less defined and tuneful, becoming more of a monotone "thruming" sound, with subtle changes in tone; at the 1:48 mark, mostly all I hear are the harmonic overtones of the infra-bass line, with barely any sense of the fundamental being played. Its bass quality overall is what I would describe as foggy. Not bad, just lacking in ease and definition. Granted, in its intended use, the P2350 would not be called upon to play these sorts of tones at high power levels into speakers of a very demanding load, whereas the 775's are designed just for this sort of performance.
Fortunately, a good deal of the music I have does not bring undue attention to the P2350's weakness in this area (unfortunately, a small majority of it seems to), and the P2350's performance in the bass regions of 40Hz on up seems to be quite good.
More positively, though, running the amp full-range, with the sorts of music I normally listen to, at the sort of levels I normally listen at, the P2350 showed no particular weakness aside from an overall lack of definition. This actually proved to be a boon with some material, like with a very rough live recording I made many years ago of my Dad's band playing in a bar. The 775's are unforgiving in their clarity of the recording, making it sound raw and harsh, but the P2350 tames it a bit. Dad actually commented on this when he heard it, asking if I had "cleaned it up" with the computer.
Further, the P2350 does certain things pretty well indeed. Again, the comparison with my 775's is a bit lop-sided, but the P2350 does justice to midrange, and has pretty decent extension on the high-end. As I initially commented, it has the property of "air" that seems unusual in pro-amps, and even slightly elusive in well regarded hi-fi gear. The "chuffs" of a flute are sufficiently detailed, and harmonic overtones in acoustic guitar are natural and life-like. Vocals are balanced and uncolored. There is still a slight soft-focus quality to everything, but its more of a ground-state texture akin to MOSFET mist than an overt muddiness.
My unease about running it with the fans disconnected has also been alleviated. While the heatsinks get warm under my normal use, they never became anything close to hot. Using an IR thermometer after a particularly robust listening session, the heatinks were only 115-degrees F. At idle, they're just above ambient temperature by 5-degrees or so. This is compared to the typically high internal temperature of the 775's at idle (~150-degrees F near the pre-driver board).
I look forward to trying the amp with other speakers, particularly a set of stand-mounted Revels, which would not only provide a more typically easy load, but also lessen the impact of the P2350's lack of control and definition in the lowest bass regions.
Pictures to follow soon.
What a learned review. Meaningful- even to this amateur.
Actually, it was partly your discussion of the Yaqin MC-10(b)? that lead to my purchase of a Yaqin 100B.
If there weren't a few Yamaha pro amps already in residence here, this comprehensive list of observations would definitely pique my interest. Thanks for all the effort. Again!
Not a bad showing for a 20 year old possibly studio or road worn warrior with only basic upkeep. Would love to hear what you think of the Yamaha if all input/outpus/controls fully deoxited, and signal caps and power caps replaced. Maybe do one channel and then listen to it compared to one channel of the HK?
Nice review, very thorough, although one can certainly say your speakers are very demanding as a test set! Are the fans supposed to run at all when cool and kick in when sensed hot, or are they supposed to run low and switch to fast when needed? Although I would agree that your measurements indicated little thermal gain, the fact that the amp's heatsinks are rather enclosed and not specifically built for convective cooling would suggest at least running the fans at lower speeds to ensure some airflow. Maybe replace with some similar sized new fans that could run slow?
BTW, which Yamaha pro amp did you consider was a pro version of the M4?
Here are the promised pictures. I was having some difficulty taking them, as I have a new, unfamiliar camera.
The P2201/2200 was the one that I was told was more or less the pro-version of the M4, and after seeing the innards, it looks to be, or at least a sibling model.
After reading this thread, I sourced a p2350 off of CL on the cheap... I use it with NS-10m studios in my studio and its been a great. I disconnected the fans and have experienced no problems.
what kind of calibrations can be done to the amp??
