Got this gem from a coworker. Sounded like lightning in a bottle when I powered it up. He said a channel was out 30 years ago when he shelved it. Worked fine for me, except that it had very loud cracking and popping coming from all channels and even at zero volume.
So I cleaned it like crazy with Deoxit and it still sounded bad. Months later, I power it on and it's not nearly as bad. It might go 10 minutes without acting up then it starts humming and doing that loud cracking. It sounds similar to dirty pots, and these are a bit hard to get to, so that might be part of it. But it's weird it's so loud at no volume.
Anyone have a place to start troubleshooting? It was in a smoke-filled environment and was/is pretty dirty. Little bit of rust on the transformers and lots of grime throughout. Surprisingly, the meter still works. My HK 330c looks mint and the meter probably died 30 years ago on that. He said a channel died, so maybe the PA transistors might be another place to look. They are larger but easy to change. Also, both 3A 250 volt fuses are dead. Not sure how it's still working like that. I'm just listening with headphones but I assume those are important. Perhaps he bypassed those? I didn't see any obvious signs of that. Yikes.
