Oceans on Venus?
ablethevoice
boatanchors rule!
We humans are pretty busy as far as exploring our solar system. We may be suffering from some sort of "arrested development" as far as getting people to other planets (a situation which seems to be more an economic/political issue rather than a technological one) , but we certainly can (and do) send robotic probes all over the solar system:
Mercury Messenger (en route)
Venus Express (in Venus orbit)
several probes on or orbiting the Moon
the intrepid little Mars rovers and the several orbiting devices still doing good work up there
the Jupiter Galileo mission (ended)
The Saturn Cassini mission (primary mission completed; now on "extended duty" in the Saturn system
and finally the New Horizons probe en route to a 2015 rendezvous/flyby with Pluto then on to the Kuyper belt and ultimately exiting the Solar system forever (like the Voyager 1 and 2 and Pioneers 10 and 11)...
And that's a very incomplete list.
Anyway, the Venus Express mission has been working quietly kind of in the background compared to other planetary exploration efforts, but that doesn't mean the VE mission hasn't been turning in good data for the planetologists to chew on:
Oceans on Ancient Venus, Study Suggests
By SPACE.com staff
posted: 14 July 2009
07:22 am ET
Venus may once have been more Earth-like, with volcanic activity and an ocean of water, a new map of the toasty planet's southern hemisphere suggests.
The map comprises over a thousand individual images, recorded between May 2006 and December 2007 by the European Space Agency's Venus Express spacecraft. It gives astronomers another tool in their quest to understand why Venus is so similar in size to Earth and yet has evolved so differently.
Because Venus is covered in clouds, normal cameras cannot see the surface, but Venus Express used a particular infrared wavelength to see through them.
Although radar systems have been used in the past to provide high-resolution maps of Venus's surface, Venus Express is the first orbiting spacecraft to produce a map that hints at the chemical composition of the rocks.
Rocky clues
The new data is consistent with suspicions that the highland plateaus of Venus are ancient continents, once surrounded by ocean that might have evaporated away into space and produced by past volcanic activity.
"This is not proof, but it is consistent. All we can really say at the moment is that the plateau rocks look different from elsewhere," said Nils Müller of the the University Münster and DLR Berlin, who headed the mapping efforts.
Water is a key to life as we know it. And though there are no signs of past or present biology on the suffocating surface Venus, some astronomers have speculated that the its clouds could harbor life.
The rocks look different because of the amount of infrared light they radiate into space. Different surfaces radiate different amounts of heat at infrared wavelengths due to a material characteristic known as emissivity, which varies in different materials.
The eight Russian landers of the 1970s and 1980s touched down away from the highlands and found only basalt-like rock beneath their landing pads.
The new map shows that the rocks on the Phoebe and Alpha Regio plateaus are lighter in color and look old compared to the majority of the planet. On Earth, such light-colored rocks are usually granite and form continents.
Granite is formed when ancient rocks, made of basalt, are driven down into the planet by shifting continents, a process known as plate tectonics. The water combines with the basalt to form granite and the mixture is reborn through volcanic eruptions.
"If there is granite on Venus, there must have been an ocean and plate tectonics in the past," Müller said.
Let's go see
Müller points out that the only way to know for sure whether the highland plateaus are continents is to send a lander there.
Over time, Venus's water has been lost to space, but there might still be volcanic activity. The infrared observations are very sensitive to temperature. But in all images they saw only variations of between 3-20°C, instead of the kind of temperature difference they would expect from active lava flows.
Still, Müller does not rule out the existence of volcanic activity on present-day Venus.
"Venus is a big planet, being heated by radioactive elements in its interior. It should have as much volcanic activity as Earth," he said. Some areas do appear to be composed of darker rock, which hints at relatively recent volcanic flows.
Scientists also debate whether past or present volcanic activity is the source of the sulfur dioxide clogging Venus' atmosphere.
SOURCE
I think you overwhelmed the crowd here with space tech date. But i'm dork, so i love this new tid bit. Anyone seen any of the pictures from the new mercury mission yet?
No, but I'm surprised no-one's mentioned the new impact that was observed on Jupiter last week. The spooky thing is that nobody on this planet saw this one coming. It was amateur astronomers who first noticed the earth-sized impact area forming near the Jovian north pole. That poor ball of gas has been taking a beating in recent years. Better it than us, though.
Another hit to Jupiter?? I totally missed that. No surprise though, if it doesn't pop up on the webpage's news section, i probably won't hear about it. I rarely watch tv news anymore.
So amateur astronomers saw this one hey? No surprise there to me actually. With the pittiful funding given for searching the skys with the big guns, a rock the size of a city could hit us tomorrow and noone here would know about it till it lit up on entry. Comforting thought isn't it?
