Sounds like an octal substitute for the ECC83 would work, Any reason for using 6SN7 rather than the equivalent 6SL7 for phase inversion?
A 6SL7 for the voltage amp state + 6SN7 for phase inverter should work pretty well, but you might need more voltage gain to be able to drive KT88s to full power after gNFB with reasonable input sensitivity. You could improve the gain of the 6SL7 there by using a constant current source for the load.
I like 6SN7s because in the 5-20 topology with a high-mu triode in front, it's easy to run at the right operating point for direct-coupling.
Why shouldn't the OP add a weblink? Nice to see other AK members take a different attitude, and offer some ideas.That's all this thread was started for, really. ... Another drive-by promo.
why substitute the EF37A for the EF86?
Hi All, this is my first thread on AK
I am constructing an amplifier that is inspired by the Mullard 5-20 amplifier. Changes to the original design are: EF37 input pentode, 6SN7 phase inverter/driver and KT88 output tubes.
Has anybody attempted something like this?![]()
Marantz 8 as a Mullard type amp uses a small signal pentode wired as a triode in the front end.
The EICO HF60 is a similar Mullard circuit. In the original design an EF86 is direct coupled to the 6sn7 phase splitter which is cap coupled to the EL34 output tubes. This is a fixed bias amp and thus is capable of around 50 watts / channel from the Acrosound OPT. One of the best mods is to adapt the circuit for kt88 output tubes which the transformers are actually better suited.
Ah yes, i am very familiar with that article. I wonder why you would rather make your circuit cathode biased instead of fixed bias on the grid?primosound, the EICO HF60 is actually the inspiration for this build. There is a thread on the web ( http://tronola.com/html/hf-60_with_6550s.html ) that I found inspiring. So one could also call this build an "autobias HF60 with KT88"
Will you aim to replicate the Eico HF60 output transformers?primosound, the EICO HF60 is actually the inspiration for this build. There is a thread on the web ( http://tronola.com/html/hf-60_with_6550s.html ) that I found inspiring. So one could also call this build an "autobias HF60 with KT88"
I am not sure that cathode bias is more reliable but it is less "problematic" especially for a tube newbie. The only thing i don't like about cathode bias for a kt88 is that you will be using 4 x 7 watt cathode bias resistors which will dissipate a lot of heat. Not only is that wasted power but also you need to account for locating the resistors in a location to properly vent that heat. Another thing is that the electrolytic caps for bypassing the resistors will have a significant effect on the sound quality.I prefer the reliability of cathode bias. KT88's are very expensive in South Africa (we have a weak currency). This amplifier is going to be used a few hundred kilometers from me.
